Free Project - 245 LED Display - Page 5
Page 5 of 6 FirstFirst 123456 LastLast
Results 161 to 200 of 222
  1. #161
    Jan 2008
    Smile well...
    Thanks.
    Like I said in my previous posts : I think my board is ok cause it's made after magu(zamfirelu http://www.zamfirelu.org/dtpt/viewtopic.php?t=254) schematics , and a read over and over again the whole thread...the problem is that I can't connect with the computer to the board and today i saw that even when the eeprom in not present on board , the LED for programing blinks the same like with the eeprom on it.
    Again thanks a million.
    P.S. : I contacted magu on his forum and i stand in touch with him last year , when i first begun to build the display , but until now he did not respond to my new posts , so that is why I decided to post in this forum that started all...
    P.P.S. : I'm impatient to continue the project because in this period I have time to do so.
  2. #162
    Jan 2008
    Smile Gata
    Yep it's working...Bill G. made me some crazy days with his xp...
  3. #163
    Sep 2003
    INDIA
    Default Wow the project Live On.
    Nice to read posting on this project in the year 2008.
    I am about to start with the project with certain modification on the PCB.
    I don't wish to drag the project on.... and on.... but , just wanted to make sure, i don't do the same mistakes (if there are any).
    Shall post my modified schematic shortly.
    regards
  4. #164
    T.Jackson's Avatar
    T.Jackson Guest
    This thread has certainly had some hits. Source code downloaded over 2,500 times!
  5. #165
    Sure is a "hit"!
    Also congrats for your new article on EPE!
    T.Jackson's Avatar
    T.Jackson Guest
    Sure is a "hit"!
    Thanks Ioannis.
    But I must say that I'm a little disappointed with EPE at the moment though. They have banned me from their forum for saying the following things ...
    a. The burglar alarm is mediocre, certainly not "ultimate" like originally publicized.
    b. Freelance technical engineering for magazines pays very poorly.
    c. I have no plans on submitting anymore projects to SC.
    So don't expect to go onto EPE's forum and ever speak openly about anything, because chances are they'll suspend your account and delete your posts.
    Not happy
  7. #167
    I have followed your very good publications up to this moment. I must say that all are excellent.
    Too pity that you had such a treatment.
    Don't give up. There are other publishers still. If like what you do, I am sure you 'll get the recognition you deserve. And you really do.
    T.Jackson's Avatar
    T.Jackson Guest
    As Melanie likes to say; "any resemblances between persons living or dead is purely coincidental"
  9. #169
    Good one!
    Aug 2007
    Default Your cascaded counter for scrolling message
    Please explain the use of D3 through D7 do make an 'or gate' for reset. Why 100K resistors?
    Why not use Q0 from each of the CD4017 counters?
  11. #171
    Quote Originally Posted by Bronx68 View Post
    The diodes are used to create a master reset from the PIC and to isolate each 4017's reset from each other. Diodes are usually a lot cheaper than logic for something as simple as this. The 100k is probably on the conservative side as far as a value, unless the designer was trying to reduce race conditions or output glitches by creating a simple RC filter.
    Tim Barr
  12. #172
    T.Jackson's Avatar
    T.Jackson Guest
    Quote Originally Posted by falingtrea View Post
    Correct!
    Further explanation -- without the diodes intact, Q0 lines on the counters wouldn't have control over their designated MR line. You simply can't tie all the Q0 lines together with anything but a semiconductor for this. As for the 100K resistors -- these ensure that there's never going to be a short between RB5 on the PIC and associated Q0 lines on the counters. When RB5 swings high, any of the Q0 lines on the counters could be either high or low. This is CMOS we're talking about here, we could even go as high as a mega ohm.
  13. #173
    Smile Sorry For A Foolish Question!!!
    HELLO T JACKSON, YOUR PROJECT IS INSPIRING AS IF TO SAY CHALLENGING SO MANY PEOPLE AROUND THE WORLD. I WANT TO BUILD THIS PROJECT AND MAGUS SITE TENDS NOT TO OPEN AND IT IS LIKE IT IS NOT IN ENGLISH(SORRY TO MAGU IF I AM WRONG). I AM THOUGH A NEWBIE TO PIC IN SOME SENSE BUT HAVE BEEEN PLAYING WITH ANALOG ELECTRONICS FOR SOMETIME. WHAT I DONT REALLY UNDERSTAND IS THE EEPROM ASPECT OF YOUR PROJECT, I WANT TO KNOW HOW YOU LOAD THE ASCII CHARACTER SET INTO THE EEPROM FROM YOUR PROGRAM, OR ARE YOU NOT USING THAT METHOD. I WAS THINKING OF DEFINING EEPROM ADDRESSES FOR ASCII CHARACTER AND THEN LOADING EACH CHARACTER IN AN ADRESS THAT I WILL LATER READ TO DISPLAY CHARACTER. DO YOU HAVE ANY DETAIL MATERIALS ON HOW TO USE EERPOM LIKE THE ONE YOU USED IN THE PROJECT? HOW FAST REALLY DO YOU FETCH DATA FROM THIS EEPROM . I AM THINKING OF BUILDING A BIGGER DISPLAY USING 3mm ULTRABRIGHT LED WITH BUFFER AND SUPPLYING ABOUT 50ma OF CURRENT WITH MULTIPLEXING I DONT THINK THE LEDS WILL GET DAMAGED? SORRY REALLY IF MY QUESTION MAY BE TOO SIMPLE FOR YOU TO REPLY TO?
    IS THERE ANYWAY I CAN GET MAGU'S LINK AND DOWNLOAD HIS STUFF. THANKS.
  14. #174
    T.Jackson's Avatar
    T.Jackson Guest
    The ASCII characters are custom, specific only to this project. They are programmed into the eeprom one byte at a time, whereas each byte represents data for the column in the character. Each column of data for a character is assigned a unique address in the eeprom and all the columns are collated together to form the character. It is impossible to explain the entire inner workings of the system in just a few paragraphs. I don't recommend this project for anyone who is new to pics / electronics.
    Trent Jackson
  15. #175
    Aug 2007
    Default programming different displays
    Trent,
    I am also designing a similar scrolling sign. I am storing the entire character set in the PIC program memory. I then plan to fetch the characters out by switches to build a buffer that contains the message. Any insight on this approach? Did you look at this approach?
  16. #176
    T.Jackson's Avatar
    T.Jackson Guest
    Give me a 100 engineers and I'll give you 100 different solutions to the problem. This kind of project is really quite abstract, my solution is far from the best and or the cheapest. I haven't really explored other possibilities well enough to make any suggestions. Using single sided PCBs was a silly thing to do (this is why it wasn't published)
    Trent Jackson
  17. #177
    Default Re:eeprom Question
    Hello Jackson, I Have Built This Project Before Using The Pic Code Space For Storing My Character Defintion, But The Message Had To Be Fixed And Each Time I Had To Reburn The Pic For A New Message To Be Displayed, This Is Where Yours Has Advantage Over Mine. The Only Thing I Have Not Really Worked With Is Eeproms Because I Hardly Find Them Around Where I Live And The Common Ones Close To Me Is The 27c512 Types, Can This Act As A Replacment Even With Modifications, So That I Can Do A Few Breadboarding To See How It Works?
    Thanks For The Previous Reply To My Post.
  18. #178
    Quote Originally Posted by inspired4real View Post
    A common one close to you is the 27C512? Where are you? In the PC salvage yard from yester-year?
    A 27C512 is a 64K x 8 EPROM. Great choice, if you're up to driving 16 address lines, 8 data lines, along with a few control lines, and like to wait around with a UV eraser just to change one byte at a time.
    A much better choice would be a 24LC1025, 64K x 8 SERIAL EEPROM. 2 wires, reprogrammable in circuit, probably faster access times...AND PBP supports it with I2CREAD/I2CWRITE.
    Not saying that interfacing with a parallel EPROM isn't possible...It certainly is and not really that hard...But WHY?
  19. #179
    T.Jackson's Avatar
    T.Jackson Guest
    I believe that the 512 would be a drop in replacement for the 256. Both use word sized addresing and are pin for pin compatiable.
    Trent Jackson
  20. #180
    T.Jackson's Avatar
    T.Jackson Guest
    Hey Jeremy,
    With a 27c256 -- how do you restrict the electron flow to and from the data pins to precisely 33 p/uS? It's probably really simple to do, alas, so am I.
    Don't ask me why I need to know, instead perceive it as a completely "abstract" (theoretical) -- sort question.
    Trent Jackson
  21. #181
    A 27C512 is a direct drop in replacement for the 24LC256?
    Only with a hammer and a dremel tool...and some of those mushrooms you've got laying around...
  22. #182
    Well, you're a smart guy, all that college edgjamakayshun and the double-naught secret service and all.
    You should be able to figure it out.
  23. #183
    T.Jackson's Avatar
    T.Jackson Guest
    I made an assumption. I actually thought that he was referring to a 24LC, because given that the micro only has 18 pins -- it's impossible to directly interface it to a 27c without a 4040, 12-BIT, BCD counter (or similar) for the parallel addressing. Even then there would be insufficient IO pins remaining for the rest of the project. On top of that -- playing around with eproms isn't a chore for the beginner. Perhaps I'm totally mistaken.
    Trent Jackson
  24. #184
    Trent Jackson
    Neither is playing with PICs, but soooo many think otherwise...
    Maybe I'M totally mistaken.
  25. #185
    T.Jackson's Avatar
    T.Jackson Guest
    I disagree. Languages like PBP makes playing around with PICs a chore for the beginner. But implementing a 27c256 eprom into the equation does require much extra knowledge than the PBP manual can depict.
    Trent Jackson
  26. #186
    Jun 2008
    Hello members
    This is not quite relate with this topic, but I thik it may be usefull.
    I need to do increase power suply for led display to +7V - 9V instead +5V wich is now. Row drivers is irf9530 (from mcu thru 1K on gate, +5V sors, drainon led row), and column driver is HC164 + ULN2803.
    Instead of irf9530 I try with BD242 (and few others), but if I increase suply on emiter above 5.5V, transistor is fully conductive (colector - emiter), and every led is on. With +5V on emiter everything is ok, but leds are with verry poor light.
    When I replace ULN2803 with 8xBS170 (n-fet), I have little better result but still not good enough.
    All this is without current limiter ressistors.
    Leds are red, 2 leds in series for 1 dot.
  27. #187
    T.Jackson's Avatar
    T.Jackson Guest
    leds are current dependent, not voltage.
    Trent Jackson
  28. #188
    Jun 2008
    Yes, but here I have two leds in series, and supply of +5V. I have voltage drop of 1.2-1.6 on ULN drivers, and rds on 9530 0.30 ohm. I guess I need to increase voltage?
    Rele
  29. #189
    Each led could use 2 volts so an increase is recommended.
    Aug 2008
    Default DOT-MATRIX display
    i need a software and hardware about dot matrix message display using wireless keyboard.
    Use wireless keyboard to sent the data to dot matrix message display....
    Anyone can help me???
    Pls.........
  31. #191
    Quote Originally Posted by yupng View Post
    i need a software and hardware about dot matrix message display using wireless keyboard. Use wireless keyboard to sent the data to dot matrix message display.... Anyone can help me??? Pls.........
    Don't ask for much do ya...
    What is your skill set?
    Which PIC do you want to use?
    What sort of hardware would you like to use?
    What kind of wireless transmission protocol are you planning on using?
    Lost yet?
    Try eBay...
  32. #192
    Aug 2008
    Lost yet?
    Try eBay...
    What i want is use two microcontroller(MCU) to build this project. One MCU is connect to PC keyboard and transmitter(using RF or IR to transmit the data).Another MCU connect to receiver(can be IR or RF circuit) and dot matrix. I found one similar project but i cant found the datesheet for the MCU used in this project. I also don't understand the code.
  33. #193
    And didn't answer ANY of the previous questions...
  34. #194
    Aug 2008
    i still doing the research for this project. So i not confirm what hardware are require for this project. I hope anyone has this similar project can post it to me. Actually my project topic is <Wireless Announcement Board>.
    Any information that related to this project also can post to me.
    Thanks.......
  35. #195
    Thanks.......
    I'd doubt anybody can help you until you help yourself.
    Until then, sounds like you might want to use something prebuilt:
    http://www.sparkfun.com/commerce/pro...roducts_id=760
  36. #196
    Aug 2008
    I had done this project before but not with wireless. I use RS232 port sent the data from pc to dot-matrix display module. Now, i need to improve it to be wireless.
    The problem is :
    How i send out the data via wireless.
    How to translate the receive data and display it on dot-matrix display module.
    Anyway........thanks for your reply.
    Thanks.......
  37. #197
    You can use radio modules like these(take your pick)
    http://www.rentron.com/PicBasic/RemoteControl.htm
    to send serial data.
  38. #198
    Aug 2008
    Anyone can help me do a "wireless announcement board" using dot-matrix.
    The data(text) is send out from keyboard via wireless to dot-matrix display.
  39. #199
    T.Jackson's Avatar
    T.Jackson Guest
    20k
    There's so much psychology in music heh
    Trent Jackson
  40. #200
    T.Jackson's Avatar
    T.Jackson Guest
    Or would you prefer a 6 million dollar lawsuit?
    Trent Jackson
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 06:14
  2. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 08:42
  3. Replies: 2
    Last Post: - 14th July 2008, 22:11
  4. 245 Led Matrix Display (as constructed by Magu)
    By magu in forum Code Examples
    Last Post: - 29th June 2007, 00:07
  5. LCD will not start
