Hi Magu,
Yes, with a 10MHz crystal you must use HS.
The Watchdog Timer should be set to ON for PicBasic Pro programs.
What you can do:
If you have an oscilloscope you can test if the 10MHz crystal oscillator
is working. (Connect the oscilloscope probe to the PIN 15 OSC2/CLKOUT).
Also possible:
Remove all the ICs from the board with the exception of the PIC.
Program the PIC with a program that will make the LED1 on RA4 blink.
You will have to write a program yourself or find someone willing to do it for you.
(Note that you can use any programming language). Program the PIC with the HEX
file you get after compiling your program. Once you get to "blink LED1 program" running,
try again to program the PIC with the HEX file posted by Trent.
I don't use PIC microcontrollers so I cannot help you further.
Best regards,
Luciano
