Free Project - 245 LED Display
Results 1 to 40 of 222
    Italy
    Hi Magu,
    For now use the seven 180 ohm resistors while testing.
    You will replace these resistors with the original 18 ohm
    resistors when the system works.
    While testing with the 180 ohm resistors:
    Once the LEDs are driven by the PIC it might be that, in order
    to see the LEDs, you will have to reduce the light in the room
    where you are testing. This will not be necessary once you replace
    the 180 ohm resistors with the original 18 ohm resistors.
    Modify your PCB, connect the pin 15 of IC3 to the
    pin 10 of IC7 via the 100k series resistor which is already
    present on the schematic.
    Place a 100nF capacitor close to each IC present on the circuit.
    This capacitor is connected to the pins VDD and GND of the IC.
    This capacitor must be close to the ICs. (Max. 10mm).
    Program the microcontroller with the HEX file posted by Trent in
    the first post of this thread.
    Plug all the ICs in their sockets. Follow the instructions posted
    by Trent. Power on the board and the circuit should work.
    Best regards,
    Luciano
    May 2007
    Quote Originally Posted by Luciano View Post
    Hi Magu,
    Best regards,
    Luciano
    it dosen`t work. i program the pic with ICPROG (plug the programer in serial port, open hex file, -> PRogram all)
    . these is a picture of the board with all the components included the caps. http://www.zamfirelu.org/led/board.jpg
    Italy
    Hi Magu,
    Remove the jumper "program". Do not use a jumper, use a push button.
    Best regards,
    Luciano
    May 2007
    Hi Magu,
    Best regards,
    Luciano
    i remove the jumper i i use a push button but doesen`t work. when i push the button the led light but doesen`t remain lighting.
    T.Jackson's Avatar
    T.Jackson Guest
    What config fuses do you have set?
    May 2007
    OSCILATOR : XT , FUses: wdt, pwrt, mclr, boden.
    Italy
    Hi Magu,
    Disconnect the serial cable from the board.
    The RX LED1 must stay ON after you release the push button "Program".
    If the LED1 does not stay ON after you release the push button "Program",
    then the program is not running in the PIC.
    Note that when the serial cable is connected to the board, and you press
    the "Program" push button, the LED will stay ON until the first 4 bytes are
    received. (Until you press the button "Program Message To The Display EEPROM"
    in the VB Application). After that the first 4 bytes are received, the LED is
    toggled and will be toggled again after the next 4 bytes are received continuing
    in the same way until the last byte of the message is received. So the LED is
    blinking while receiving the data from the PC.
    Again, with the serial cable disconnected, the RX LED1 must stay ON after you
    release the push button "Program". If not, then the program is not running in the PIC.
    Trent, can you please confirm my last sentence?
    Best regards,
    Luciano
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 09:42
  3. Replies: 2
    Last Post: - 14th July 2008, 23:11
  4. 245 Led Matrix Display (as constructed by Magu)
    By magu in forum Code Examples
    Last Post: - 29th June 2007, 01:07
  5. LCD will not start
