Free Project - 245 LED Display
Results 1 to 40 of 222
Threaded View
  1. #11
    Italy
    Hi Magu,
    For now use the seven 180 ohm resistors while testing.
    You will replace these resistors with the original 18 ohm
    resistors when the system works.
    While testing with the 180 ohm resistors:
    Once the LEDs are driven by the PIC it might be that, in order
    to see the LEDs, you will have to reduce the light in the room
    where you are testing. This will not be necessary once you replace
    the 180 ohm resistors with the original 18 ohm resistors.
    Modify your PCB, connect the pin 15 of IC3 to the
    pin 10 of IC7 via the 100k series resistor which is already
    present on the schematic.
    Place a 100nF capacitor close to each IC present on the circuit.
    This capacitor is connected to the pins VDD and GND of the IC.
    This capacitor must be close to the ICs. (Max. 10mm).
    Program the microcontroller with the HEX file posted by Trent in
    the first post of this thread.
    Plug all the ICs in their sockets. Follow the instructions posted
    by Trent. Power on the board and the circuit should work.
    Best regards,
    Luciano
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 09:42
  3. Replies: 2
    Last Post: - 14th July 2008, 23:11
  4. 245 Led Matrix Display (as constructed by Magu)
    By magu in forum Code Examples
    Last Post: - 29th June 2007, 01:07
  5. LCD will not start
