Really slow digital input
Results 1 to 8 of 8
    Jul 2006
    Default Really slow digital input
    Hello,
    I am using an 18F4550 and I am trying to get it to read a digital input and turn on a LED when it is on. For some reason there is a five second pause when I trigger the pin. When I reset the PIC and plug it back in, there is no pause. The pause only occurs when I trigger the pin. The code I am using is below.
    It may be important to note that I am using about 10V with a 22K resistor for input, if that has anything to do with it.
    rts var porta.2
    cts var portd.3
    led var portd.2
    input rts
    output cts
    output led
    ADCON1 = %00001111
    low led : low cts
    while rts = 1
    high led
    wend
    low led
    Can anyone help?...skimask?
    -Mike
    Quote Originally Posted by mbw123 View Post
    Hello, I am using an 18F4550 and I am trying to get it to read a digital input and turn on a LED when it is on. For some reason there is a five second pause when I trigger the pin. When I reset the PIC and plug it back in, there is no pause. The pause only occurs when I trigger the pin. The code I am using is below.
    rts var porta.2 : cts var portd.3 : led var portd.2 : input rts : output cts
    output led : ADCON1 = %00001111 : low led : low cts
    while rts = 1
    high led
    wend
    low led : goto main
    -Mike
    Is the 22K resistor in series with the pin or is it across Vdd or Vss or what?
    Also, write a quick program that turns the LED on and off for 1 second each. This will make sure your PIC isn't running on the internal/backup/failsafe 37khz oscillator for some silly reason.
    (4mhz / 62.5khz (desired freq vs actual freq) = 64............64 x 72ms (power up timer) = 4.6 seconds...the math adds up fairly well).
    Jul 2006
    Thanks for the response.
    The resistor is in series with the pin. And I'll try to test the LED program right now.
    -Mike
    Jul 2006
    OK, this is really weird. I made a LED blink program but it takes like 5 seconds to turn on and then it doesn't blink, it just stays on. How do I turn off the 37khz oscillator? Thanks.
    -Mike
    Jul 2006
    Alright, I got it working by changing adding "DEFINE OSC 4." So it works fine now. However, when I tried the original program there is still a pause. When I turn the pin off there is no pause, only when I turn it on is there a pause. Also, when I leave the pin on but reset the PIC it recognizes it immediately.
    I am almost positive it has something to do with my input. I am using a serial port (with RTS as the input) and when the RTS is off it says that it is -10 volts. Should I put a diode there or something? I really have no idea how this works, so even a little help understanding this would be greatly appreciated.
    -Mike
    Questions:
    1. Does it take 5 seconds for the LED to come on or does the LED stay on for 5 seconds.
    2. Have you tried not using serial input to turn on the LED. Not just make it blink like Skimask had you do, but re-write so when PIN? is high LED on. (simple switch )
    I am getting at, if the above #2 works fine you may want to look at the signal duty cycle coming in from the serial.
  1. Sony LanC Program
    By l_gaminde in forum Code Examples
    Last Post: - 25th September 2009, 18:51
  2. How do I get 18f452 pin 10 set as digital input?
    Last Post: - 26th May 2007, 18:32
  3. 18F4550 digital input
    By mbw123 in forum mel PIC BASIC Pro
    Last Post: - 29th March 2007, 02:43
  4. Timing input pulses and re-outputting them
    Last Post: - 28th February 2007, 01:50
  5. Analog pins for digital input
    Last Post: - 9th September 2005, 00:32
