If you can't get it to work internally, then at least try to get it to work with an external clock. Then work towards getting the internal to work. It might be somehow stuck on one of the lower speeds (32khz or whatever) and you're not waiting long enough.
Write a 'blink the led' code...make it work on the external, then switch...see what happens...
