Pic16f88
Results 1 to 9 of 9
Thread: Pic16f88
    Lightbulb Pic16f88
    TRYING TO USE THE INTERNAL OSC ON THIS CHIP
    ANYONE KNOW THE CORECT SYNTAX?
    DEVICE pic16F88, INTRC_OSC_NOCLKOUT
    DOES NOT WORK
    THANKS
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by jcleaver View Post
    DOES NOT WORK
    THANKS
    If you can't get it to work internally, then at least try to get it to work with an external clock. Then work towards getting the internal to work. It might be somehow stuck on one of the lower speeds (32khz or whatever) and you're not waiting long enough.
    Write a 'blink the led' code...make it work on the external, then switch...see what happens...
    Feb 2003
    Salt Lake City, Utah USA
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    SWITZERLAND (french speaking)
    Default PIC16F88 fuse settings syntax
    These are the settings I use everyday:
    ' Oscillator
    ' EXTRC_OSC_CLKOUT, EXTRC_OSC_NOCLKOUT, EXTRC_OSC, INTRC_OSC_CLKOUT
    ' INTRC_OSC_NOCLKOUT, INTRC_OSC, EXTCLK_OSC, EC_OSC, HS_OSC, XT_OSC, LP_OSC
    @ DEVICE PIC16F88, INTRC_OSC_NOCLKOUT
    ' Program Code Protection
    ' Set to PROTECT_OFF for Development Copy
    ' Set to PROTECT_ON for Release Copy
    @ DEVICE PIC16F88, PROTECT_OFF
    ' Watchdog Timer
    @ DEVICE PIC16F88, WDT_ON
    ' Power-On Timer
    @ DEVICE PIC16F88, PWRT_ON
    ' Master Clear Options (Internal)
    @ DEVICE PIC16F88, MCLR_ON
    ' Brown-Out Detect
    @ DEVICE PIC16F88, BOD_ON
    ' Low-Voltage Programming
    ' If set to ON, RB3 is no longer available!!! see d.-s.
    @ DEVICE PIC16F88, LVP_OFF
    ' Data Memory Code Protect
    ' Set to CPD_OFF for Development Copy
    ' Set to CPD_ON for Release Copy
    @ DEVICE PIC16F88, CPD_OFF
    ' DEBUGGER
    @ DEVICE PIC16F88, DEBUG_OFF
    ' CCPM1 choice:
    ' Set OFF for function on RB0 (default)
    ' Set ON for function on RB3
    @ DEVICE PIC16F88, CCPMX_OFF
    Fuses ending with "ON" or "OFF" can be set vice-versa.
    Roger
    I use this on my 'F88 program and it works without any problem.
    OSCCON = $60 'set int osc to 4mhz
    ANSEL = 0 'ANALOG INPUTS ALL DIGITAL
    ADCON0 = 0 'AD MODULE OFF
    CMCON = 7 'COMPARATORS OFF
    @ DEVICE MCLR_OFF, INTRC_OSC, WDT_ON, LVP_OFF, BOD_OFF, PWRT_ON, PROTECT_ON
    Default additional info
    pic works fine with external osc
    still having issues with internal pic manual seem to indicate it has 2 internal osc commands and three osc speed with 8 the defualt but does not list the
    commands
    1. LP Low-Power Crystal
    2. XT Crystal/Resonator
    3. HS High-Speed Crystal/Resonator
    4. RC External Resistor/Capacitor with
    FOSC/4 output on RA6
    5. RCIO External Resistor/Capacitor with
    I/O on RA6
    6. INTIO1 Internal Oscillator with FOSC/4
    output on RA6 and I/O on RA7
    7. INTIO2 Internal Oscillator with I/O on RA6
    and RA7
    8. ECIO External Clock with I/O on RA6
    4.5 Internal Oscillator Block
    The PIC16F87/88 devices include an internal oscillator
    block which generates two different clock signals;
    either can be used as the system’s clock source. This
    can eliminate the need for external oscillator circuits on
    the OSC1 and/or OSC2 pins.
    The main output (INTOSC) is an 8 MHz clock source
    which can be used to directly drive the system clock. It
    also drives the INTOSC postscaler which can provide a
    range of six clock frequencies from 125 kHz to 4 MHz.
    The other clock source is the internal RC oscillator
    (INTRC) which provides a 31.25 kHz (32 µs nominal
    period) output. The INTRC oscillator is enabled by
    selecting the INTRC as the system clock source or
    when any of the following are enabled:
    • Power-up Timer
    • Watchdog Timer
    • Two-Speed Start-up
    • Fail-Safe Clock Monitor
    seems to have somethjing to do with the " fosc : " seting but have never seen this used
    also i want to use the internal ad convertor
    thanks for any help
    Default OSCCON register
    Look at the OSCCON register (it's in your post!).
    You'll be able to select the desired frequency.
    Roger
    Apr 2006
    New Hampshire USA
    Wink the OSCCON register
    See if this forum thread helps.
    http://www.picbasic.co.uk/forum/showthread.php?p=15901
    -Adam-
    DOES NOT WORK
    THANKS
    You're absolutely right, it won't work as you wrote it.
    1) you must state the "@" in front of the word "DEVICE...";
    2) show you code; if you need some help, give some valuable info;
    3) SHOUTING never helps... and isn't motivating others to help you;
    4) here is a complete fuse initialisation - don't edit, just copy/paste it because this works!!!. It is not the shortest example but, at least, you can see every fuse declaration separately.
    @ DEVICE PIC16F88,INTRC_OSC_NOCLKOUT
    @ DEVICE PIC16F88,PROTECT_OFF
    @ DEVICE PIC16F88,WDT_OFF
    @ DEVICE PIC16F88,PWRT_ON
    @ DEVICE PIC16F88,MCLR_ON
    @ DEVICE PIC16F88,BOD_OFF
    @ DEVICE PIC16F88,LVP_OFF
    @ DEVICE PIC16F88,CPD_OFF
    @ DEVICE PIC16F88,DEBUG_OFF
    @ DEVICE PIC16F88,CCPMX_OFF
    If you then want your PIC to work at 4MHz, add this:
    OSCCON = %01100000  '4MHz
    The advantage of SHOUTING is that some people can take their glasses off to read this post
    Roger
  1. RX TX modules - intermitent communication
    Last Post: - 11th June 2009, 00:13
  2. pic16f88 & voltage
    By rdxbam in forum mel PIC BASIC Pro
    Last Post: - 17th February 2009, 09:14
  3. Ghange code from PIC16F877A to PIC16F88
    Last Post: - 12th March 2008, 16:09
  4. Replies: 8
    Last Post: - 7th December 2006, 15:42
  5. PIC16F88 problem with TOGGLE command?
    By russman613 in forum mel PIC BASIC Pro
    Last Post: - 17th September 2006, 23:31
