need help on display problem
Results 1 to 20 of 20
    Screen slowly turn into black box.
    Sounds like a power problem of some sort to me. Double check the datasheet, you might need a negative voltage on the contrast pin.
    LCD_INITMS? Where'd you get this from?
    sory for the misunderstanding..what i mean for the screen slowly turn into black row is when im trying to adjust the pot value which is the lcd contrast value..as ive learn from the online tutorial, it mention to adjust the pot for the contrast by turn off, adjust and turn it on back..so the result is the box become darkest every time im increase the pot value... LCD_INITMS? this define was advice to me by some other expert people like u..which use to give some delay during initialise. even i never see it on any tutorial but amazingly its been recognize by microcode..n as an addition he had advice me that by compiling my source using Micro, i have to chop off the ADC section.
    Quote Originally Posted by sixty9sandals View Post
    DEFINE LCD_INITMS...if you think that's recognizable by the compiler, try:
    DEFINE LCD_LOADOFCRAPFORTROUBLESHOOTINGMS 1
    Now what?
    Hi sixty9sandals,
    Did you ground the RW pin ?
    Hi sixty9sandals,
    hi joe..
    ya..ive ground it..together with the vss pin.,
    Now what?
    hi skimask...
    ya..u absolutely rite..my bad..by reading the previous tread send by others..is it possibly coz by using the port d as the data lines?
    hi skimask...
    Nah, Port D is what everybody uses by default unless they've got some reason to use another port.
    Which LCD module are you using, part number?
    And is this correct:
    LCD D0-D7 on PortD.0-PortD.7 (make sure you've got the order correct 0-0, 1-1, 2-2, etc)
    LCD A0 on PortC.2
    LCD E on PortC.3
    LCD R/W grounded
    You aren't setting C.2 and C.3 to outputs directly, but PBP should handle that for you.
    You did say you were using the 16F877. Are you sure your programmer is set for the 16F877 and not the F877A? Can you rewrite the code and make an LED blink or anything. Who knows...maybe the thing isn't even running.
    Default Just a chance
    i ve recheck all the wiring..n its all just like the diagram..
    I have not upgraded to the latest version of PBP, but my GREEN BOOK shows the example "diagram" for a 4 bit set up.
    The code I see is for 8 bit.
    It is very late for me so maybe I am missing something.
    <b> Nice Catch</b>
    If you're wiring is for 4 bit, and your code is for 8 bit, then you need to add:
    DEFINE LCD_BITS 4
    otherwise PBP defaults to 8 bits
  1. Hdsp 21xx display
    By Original in forum mel PIC BASIC Pro
    Last Post: - 7th June 2012, 21:07
  2. Replies: 14
    Last Post: - 26th September 2007, 06:41
  3. 7-segment display blinking problem?
    By serdar_ozcan in forum mel PIC BASIC Pro
    Last Post: - 14th March 2006, 15:43
  4. 7 segment digit problem (using Mister E's code)
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 9th September 2005, 21:25
  5. 4x20 LCD Display Problem
    By kayki in forum mel PIC BASIC
    Last Post: - 24th August 2005, 16:42
