using ISD2560 on PIC18F4620
Results 1 to 13 of 13
    Hi Rookie. You really don't need a PIC to run that chip. You can use a diode matrix for addressing purposes. Also, DON"T become attached to it. Winbond released an End Of Life to that series and is discontinuing it. We are using the ISD2575 (same thing with 75 seconds) and I'm in the process of redesigning our boards to use (probably) the newer ISD1750. It offers the ability to operate stand-alone or SPI with a microcontroller.
    Nov 2007
    Old Lyme, Connecticut
    Quote Originally Posted by peterdeco1 View Post
    I realize that this is an old thread, but I'm curious if you did go with the ISD1750? If so, I'd be interested in hearing how it went.
    I'm also updating an old project that used a now obsolete Winbond chip. I thought I could simply pulse the FWD input to get to the desired recording, but the ISD chip responds too slowly that way. I'm going to pursue the SPI interface, next. If there's any interest, I'll post my results.
    I'm new to this forum, so I'm not sure if I should post here or start a new thread dedicated to interfacing with the ISD chips. Anyone have a suggestion?
    - Don
    Hi Don. Never persued the ISD1750. Requires a whole new protocol from what I'm used to. I've been using the ISD5008 for a while now and with the quantities we order, the price is almost equal to what we were paying for the 2575. So this is the chip we will use to replace it.
    Nov 2007
    Hi Peter,
    Thanks for the quick reply. It appears no one is "upgrading" to the ISD1700 series for their PIC projects. My concern was with the SPI code, but since it looks like SPI is soon going to be the only way to talk to these things, I'm going to give the ISD17120 a shot.
    - Don
    Let me know Don. Perhaps we can share some code.
    peterdeco1, Here is a subroutine I wrote quite a few years back for a repeater. The plyrec flag is for playback/record. It uses the chip select, interrupt, eom, mosi and clock. It was for recording and playing back 6, 20 second messages from a 120 second part. I hope it helps....
    ISDDVR1:' SPI DRIVER FOR ISD-33120 DVR
    ISDSEL = 0 'SET <>CE LOW
    SHIFTOUT MOSI,SCLK,0,[%00100\5] 'SEND POWER-UP COMMAND
    ISDSEL = 1 'SET <>CE HIGH
    PAUSTIME = 30 'WAIT FOR POWER-UP SEQUENCE TO COMPLETE
    GOSUB WAITIME
    IF PLYREC=0 THEN REC 'CHECK FOR RECORD MODE
    PLY:
    SHIFTOUT MOSI,SCLK,0,[((DRCHANL MIN 5)*133)\11,%11100\5] 'START PLAYBACK @ ADDRESS
    PAUSE 1
    SHIFTOUT MOSI,SCLK,0,[%11110\5] 'CONTINUE PLAYBACK @ ADDRESS
    TIMSTAMP = 0
    WHILE TIMSTAMP<20000 'WAIT FOR 20 SEC or UNTIL EOM
    IF EOM_OVF=0 THEN CLRDR 'CHECK FOR EOM, IF NOT BUSY THEN FINISHED
    WEND
    GOTO CLRDR 'NO EOM BIT TO BE FOUND IN TIME
    REC:
    TIMSTAMP = 0
    WHILE TIMSTAMP<3000 'START TIMING LOOP FOR UNKEY (~3 SEC)
    IF COR=1 THEN CONTREC 'WAIT FOR COR/COS TO DROP
    WEND
    GOTO CLRDR 'NO UNKEY TO BE FOUND IN TIME
    CONTREC:
    TIMSTAMP = 0
    IF COR=0 THEN SREC 'CHECK FOR COR/COS PRESENT
    WEND
    GOTO CLRDR 'TIME IS UP SO, FINISH OPERATION
    SREC:
    SHIFTOUT MOSI,SCLK,0,[((DRCHANL MIN 5)*133)\11,%10100\5] 'START RECORD @ ADDRESS
    PAUSE 1
    SHIFTOUT MOSI,SCLK,0,[%10110\5] 'CONTINUE RECORD @ ADDRESS
    TIMSTAMP = 0
    WHILE TIMSTAMP<19900 'WAIT FOR 19.9 SEC or UNTIL EOM
    IF EOM_OVF=0 OR COR=1 THEN CLRDR 'IF COR/COS DROPPED OR EOM THEN STOP RECORD
    WEND
    CLRDR:
    SHIFTOUT MOSI,SCLK,0,[%00000\5] 'STOP REC/PLY @ POWER DOWN
    Nov 2007
    Well Dave,
    I think you've saved me a ton of trial and error! Thanks!
    - Don
    Nov 2007
    Peter,
    Definitely!
    - Don
    Thanks Dave. Your code is almost identical to the 5008 code except there are 3 SHIFTOUTs to get the 5008 to go from record to play. Once in play, the first 2 config bits are stored in a temporary register so you can just repeat the 3rd to do things like message cueing.
  1. PIC18F4620 Programming problem
    By JavPar in forum mel PIC BASIC Pro
    Last Post: - 6th December 2008, 05:21
  2. ADCIN with PIC18F4620
    By Brian J Walsh in forum mel PIC BASIC Pro
    Last Post: - 4th July 2008, 02:25
  3. PIC18F4620 Using the Internal Oscillator
    By kiwipiper in forum mel PIC BASIC Pro
    Last Post: - 23rd October 2007, 09:07
  4. PIC18F4620 not Target Device
    Last Post: - 17th October 2007, 20:42
  5. PIC18F4620 Troubles
    By CluckShot in forum mel PIC BASIC Pro
    Last Post: - 16th May 2007, 04:02
