Code Protection
Results 1 to 12 of 12
Thread: Code Protection
    Quote Originally Posted by JoeEvert View Post
    Yes, I looked at the data sheet, unfortunately it does not discuss the code protection bit in detail. It says it exists but does not discuss what the ramifications are with using it. The datahsheet says this is bit 13 of the configuration word? Specifically how is this used? If I set the bit to 1 it implies that the code is protected. Is that written at device program time? Is there a directive to indicate this? Specifically I am looking for how to implement this in my code or is this only implemented in the firmware program options. On the ME programmer there is a code protection option. Does that do the same thing? The application does not remember the setting I choose and appears to default to disabled when it loads. Thanks,
    And the datasheet isn't going to discuss code protection in detail, that's the whole idea. Suffice to say, if you try to read a code protected device the 'normal' way, you'll get garbage.
    You set the appropriate config word bit as required. You program the flash, eeprom, id, etc, verify it all, the write the config word. The PIC isn't protected until that config word with that particular config bit is written.
    If you're programmer doesn't remember it's settings, either it's not supposed to (hard to believe) or you've got a software problem. Probably something to do with path's or something. I don't have that programmer, I don't know. Generally, I set my bits in the source code, and don't worry about it.
    New Zealand
    Just set code protection in your programmer - (blowing fuses) I believe if you want to be very secure you can make a little socket which grounds all the pins except the PGM pin and then apply like 24V to the PGM pin which will render that pin usless.
    Jan 2007
    Exclamation 12C508A code protect problem
    Hi All,
    I programmed a 12C508a chip and wrote code in configuration to protect the code. I programmed it with EPIC Programmer Ver2.44 and also set the code protection to all in options menu.
    The chip is programmed but not protected. When I Read data in EPIC Programmer, it reads the chip and by menu View code it show the contents of the program in Hex format.
    Why it does not protect the chip? Any help in the problem???
    Shahzad
    Quote Originally Posted by thetrueman View Post
    Are you sure you didn't set them to ALL OFF?
    Jan 2007
    Default 12C508A Code Protection
    Yes while programming at the top of code I confing Code Protect ON and while downloading to chip, in the EPIC programmer software options menu I set Code protection to ALL.
    I just read this chip with ALL-100 Universal Programmer and it reads the chip 12C508A. So how to protect the code to be invisible to others???
    Sep 2007
    USA, CA
    Some programmers have a setting to read the config in the hex file or not... maybe your programmer is using default settings.
    Hi, Thetrueman
    1) could you show us your config settings ( from the program AND read from the chip ).
    2) now ... keep cool, but the C series chips are really easy to " crack" ...
  1. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  2. Loop with two motor and 2 sensors
  3. Error 0X0000008E when connecting a 18F2550 USB HID
    By FranciscoMartin in forum USB
    Last Post: - 16th October 2008, 18:20
  5. Can't remove code protection of 16F88!!!
    Last Post: - 22nd December 2006, 14:18
