TTL input - 3rd states possible?
Results 1 to 27 of 27
    SWITZERLAND (french speaking)
    Paul,
    Previously, I have mentionned a doubt I had about the ANSEL (analog) settings because I agree with you, in DIGITAL, I can have only two states (0 & 1).
    Do I have to conclued that the reading of a "3 states ports" can be achieved only by means of software (as stated in the "Tips & Tricks" doc) and that it is not possible by reading the inputs states on the PIC's pins?
    I don't care about the Z state.
    I would like to read only both "0" and "1" states (2 buttons)...
    Roger
    T.Jackson's Avatar
    T.Jackson Guest
    Post Valid TTL Levels
    TTL - Transistor-Transistor-Logic, valid logic low between (0 - 0.8v), while valid logic high must be within the region of (2 - 5v) Any where between (0.8 - 2v) may be read as either logic high or low. You can't predict it. Could even oscillate.
    CMOS - Complementary-Metal-Oxide-Semiconductor on the other hand can be feed with up to 26% of VCC for a logic low and a minimum of 73% of VCC for a logic high.
    This industry standard ensures that CMOS is guaranteed to produce no more than 26% of VCC for a low output and no less than 73% of VCC for a high out.
    CMOS is far, far superior to TTL in that it mirror's current from in to out. Some CMOS chips can even partially function even without supply. i.e. if there's something on an input you still get something on an output. TTL is however much more robust. That's the trade off. Plus TTL has a much bigger fanout,
    which means that more inputs can be driven from an output.
    Trent Jackson
    Feb 2005
    Kolkata-India
    Default Not tested hastily made after reading post
    This is just an idea using the MChip Tips n' Tricks. No timer, no comparator just an idea. Flotulopex please test it out. Others on the forum please comment if it is crap.
    READ_SWITCH:
    TRISA.0 = 0             ' MAKE THE PIN AN OUTPUT
    PORTA.0 = 0             ' MAKE IT LOW
    PAUSE 100               ' WAIT FOR THE CAPACITOR TO DISCHARGE
    TRISA.0 = 1             ' MAKE THE PIN AN INPUT
    PAUSE 100               '
    IF PORTA.0 = 1 THEN SWITCH_HIGH   '
    LED1    = 0             ' DEFINATELY NOT HIGH
    PORTA.0 = 1             ' MAKE IT HIGH
    PAUSE 100               '
    PAUSE 100               '
    IF PORTA.0 = 0 THEN SWITCH_LOW   '
    LED0       = 0          ' DEFINATELY NOT LOW
    GOTO READ_SWITCH
    SWITCH_LOW:
    LED0 = 1
    GOTO READ_SWITCH
    SWITCH_HIGH:
    LED1 = 1
    GOTO READ_SWITCH
    P.S. - The code can be made shorter!!
    Sougata
    Default still blinking
    Hello Sougata,
    Thanks for your code (I copied/pasted it without any change and worked!!!). Unfortunately, the Led0 is still blinking.
    I made a code (also based on the Tips & Tricks) very similar to yours and had the same result.
    As one can multiplex 6 Leds with only 3 pins, I thought I could do something similar with buttons on 1 port.
    After a lots of trials, I think it is not feasable... or I still miss something.
    As already said, I don't care about the Z state. Only both "0" and "1" states would be used.
    Roger
    Hello Sougata,
    Curious...why are you worried about the 'Z' state?
    Is it the fact that it can 'hover' around the trip point and cause false readings if left open?
    Feb 2005
    Kolkata-India
    Question Time for your schematic and entire code
    It is possible. Did you connect your PIC according to the schematic I provided. <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1507&d=1175158348" align="absmiddle">Try increasing the pause. Please post your entire code and schematic. It is possible in one way or the other. I have chosen the Digital way. Detecting multiple switches with one pin is also possible using the ADC. By the way the circuit doesn't work when both the switches are pressed simultaneously. The 1K resistors are provided for that purpose so that you don't blow up your PS. When both are pressed most likely your PIC would read a logic high. As you get 1/2VDD and @ 5 volts it is good enough to be a logic 1. In any TTL/CMOS gate your cannot have anything other than 0 or 1 in your output whether your inout is at 0,1 or Z. So software tricks does it. By switching your port pin between input and output and detecting the holding capacitors state. I repeat please post your exact code and schematic and it should work.
    Let me clarify my understanding about your requirement.
    • You need to use only one pin of your PIC.
    • You need to connect 2 switches to that.
    • You need to determine whether your input is hanging idle (Z)
    • Switch connected to VDD was pressed (H)
    • Switch connected to VSS was pressed (L)
    I am waiting.
    Sougata
    ? I don't understand. I said I don't care about the Z state. I would like to read "0" and "1" states (= read two buttons on 1 pin).
    Sougata,
    The code I use is almost the same as yours. I'll post it this evening (I'm in the office now).
    The shematic is absolutely the same as yours but I've some different values:
    PIC16F88-4MHz int osc
    R1 = 10k
    R2/R3=1k2
    Nevertheless, you have pointed out what I was expecting.
    I'm afraid that reading states that must be defined by software will slow down the maniability of your program.
    In my case, I'm (re)making a SIMON game and when you get use to play with this, you can be quite fast on the buttons.
    I already tried with A/D; this was far to slow. RCTime was to slow too.
    I'll have another try and come back for a feedback.
    Roger
  1. Sony LanC Program
    By l_gaminde in forum Code Examples
    Last Post: - 25th September 2009, 19:51
  2. RB0 + Internal Pullup + Interrupt
    By Freman in forum mel PIC BASIC Pro
    Last Post: - 10th August 2009, 12:11
  3. LED "capacitance" won't get lower
    Last Post: - 3rd May 2007, 21:31
  4. Timing input pulses and re-outputting them
    Last Post: - 28th February 2007, 02:50
  5. Using LEDs as light sensors
    Last Post: - 30th December 2006, 23:19
