Philips PCF 8591
Results 1 to 14 of 14
    Sep 2005
    Campbell, CA
    Check the PBP mqnual. PBP *AUTOMATICALLY* sets the LSbit to the
    correct value. That is, the I2CREAD instruction FORCES the bit to "1"
    and I2CWRITE FORCES it to "0". Try it in your code, and you will find
    that it works.
    Charles Linquist
    Quote Originally Posted by Charles Linquis View Post
    that it works.
    I know. I was jumping back and forth while typing in my last post, checking the datasheet for the PCF, the manual, I2C spec's, etc. I should've hit refresh before submit!
    Feb 2005
    Kolkata-India
    Default Have you tried the hold option
    Have you tried the DEFINE I2C_HOLD 1 in your prog ? Any difference using or not using it ?
    Sougata
    Sep 2005
    Campbell, CA
    Quote Originally Posted by sougata View Post
    Yes, I tried that. No difference.
    Charles Linquist
    Feb 2005
    Kolkata-India
    Default Any luck Charles ?
    There has been no update. Please do let us know if you succeed and how.
    Sougata
    Hi, Charles
    Found a demo here ... :
    Listing 2
    ' Nuts & Volts "Stamp Applications" -- November, 2001
    ... may be it will help
    Dec 2008
    Los Angeles, CA
    Default Re: Philips PCF 8591
    Hi Charles (long time - no hear),
    Did you ever find the answer to this problem? I'm looking at using the chip, but not if there's unforseen gotchas.
    Thanks!
    Len
  1. Philips FR951 Schema needed
    By fredje in forum Schematics
    Last Post: - 19th May 2010, 20:47
  2. Problem to read a PCF 8574
    By Darklakebridge7 in forum mel PIC BASIC Pro
    Last Post: - 26th February 2007, 22:56
  3. Pcf 8583
    By srspinho in forum mel PIC BASIC Pro
    Last Post: - 26th February 2006, 20:41
  4. I2C compass - Philips KMZ51
    By barkerben in forum General
    Last Post: - 25th December 2005, 21:10
