Philips PCF 8591
Results 1 to 14 of 14
    Quote Originally Posted by Charles Linquis View Post
    Has anyone successfully read a Philips 8591 using PBP? I can "talk" to virtually any other device I have come across, but this one has me stumped. Can someone tell me what I'm doing wrong? And yes, I have pull-ups on the SCL and SDA lines!
    Code is below.
    PCF8591 CON %10010000
    SetupI2C:
    DevAddr = 0 : DevAddr = DevAddr << 1 : DevAddr = PCF8591 | DevAddr
    I2CWRITE PORTC.4,PORTC.5,DevAddr,$44,[0] ; Use internal clk, auto-increment mode
    ReadI2C:
    I2CREAD PORTC.4,PORTC.5,DevAddr,[PSByte1,PSByte2,PSByte3,PSByte4] ; Read all 4 channels
    I just read the datasheet. Check page 19, SCL freq. The PCF8591 is a 100khz device, not 400khz (or even 1mhz for that matter).
    You probably have to use:
    DEFINE I2C_SLOW 1
    in your code to slow it down a bit.
    Sep 2005
    Campbell, CA
    OK, a bit more explanation.
    I DO have the DEFINE I2C_SLOW 1 in my header,
    Also,
    The logical OR is to set the actual device address.
    The "identifier" address of the PCF 8591 is %1001xxxy,
    where "xxx" = the sub-address (as set by the 3 hardware
    addressing pins), and "y" is the Read/Write bit. I have to shift
    the sub-address (or hardware address) left with the << 1
    to align it properly.
    So, with my ORing statement, I'm actually sending
    %10010000
    (the chip has all 3 hardware address pins grounded)
    Then I'm sending $44, which is supposed to be the control byte,
    Then a data byte of "0", to tell it to start at channel "0"
    The datasheet says $44 is the command to put it in the "auto-
    increment" mode with "internal oscillator". After that, all you are supposed to have to do is read the chip.
    A READ is supposed to give me all 4 channels at once.
    The chip doesn't care what I call the bytes.
    If any of this isn't correct, please tell me. Maybe that will help me
    solve my problem.
    Charles Linquist
    Mentor, Ohio
    Smile
    Hi Charles,
    Isn't the "Write" DevAddr suppose to be different than the "Read" address with the LSB being a "0" for write operation and a "1" for a read operation?
    Thank you for the explanation of the ORing. I'm learning more here!
    BobK
    Sep 2005
    Campbell, CA
    PBP automatically changes bit0 in the string. It handles the differences between WRITE and READ.
    Charles Linquist
    Ah...and I thought for sure I had it.
    But another idea hit me looking thru the code...
    You've got the R/W set to 0, should be a 1 for a read and 0 for a write.
    Maybe, maybe not. Seems like that's the way it is for the other eeprom's I use.
    I'm a bit late on the refresh button I'm thinking! You guys already got it...
    Last edited by skimask; - 28th March 2007 at 02:32. Reason: Day late dollar short!
    Sep 2005
    Campbell, CA
    Check the PBP mqnual. PBP *AUTOMATICALLY* sets the LSbit to the
    correct value. That is, the I2CREAD instruction FORCES the bit to "1"
    and I2CWRITE FORCES it to "0". Try it in your code, and you will find
    that it works.
    Charles Linquist
    that it works.
    I know. I was jumping back and forth while typing in my last post, checking the datasheet for the PCF, the manual, I2C spec's, etc. I should've hit refresh before submit!
    Feb 2005
    Kolkata-India
    Default Have you tried the hold option
    Have you tried the DEFINE I2C_HOLD 1 in your prog ? Any difference using or not using it ?
    Sougata
    Sep 2005
    Campbell, CA
    Quote Originally Posted by sougata View Post
    Yes, I tried that. No difference.
    Charles Linquist
  1. Philips FR951 Schema needed
    By fredje in forum Schematics
    Last Post: - 19th May 2010, 19:47
  2. Problem to read a PCF 8574
    By Darklakebridge7 in forum mel PIC BASIC Pro
    Last Post: - 26th February 2007, 21:56
  3. Pcf 8583
    By srspinho in forum mel PIC BASIC Pro
    Last Post: - 26th February 2006, 19:41
  4. I2C compass - Philips KMZ51
    By barkerben in forum General
    Last Post: - 25th December 2005, 20:10
