Ac voltmeter Ampermeter
Results 1 to 5 of 5
    onur's Avatar
    onur Guest
    Default Ac voltmeter Ampermeter
    Hi
    I m doing ac 220 volt 50 hz voltmeter and ampermeter with f877. What is the best way for do this.
    I m using f877 adc.
    Thanks.
    Dec 2005
    For current:For voltage, use a unregulated DC wall transformer to drop the voltage to a safe level and a voltage divider to get it in ADC range.
    onur's Avatar
    onur Guest
    Thanks for answer.
    Another question:
    I must do fast electronic fuse using this amp. and voltmeter.
    For ex: When current over my set limit, pic output pin must be shutdown very quickly,must be more speed from main ac fuse.
    Anybody done do this before?I need some tips or schematic or code ex.
    Thanks.
    i would use a comparator interrupt. If the comparator input is greater than the reference, it jump to an Interrupt routine, in there you Shut down the external devices.
    could be done with the ADCs reading too... it's just slower.
    Feb 2007
    Question measuring AC
    Hi
    Im new to this forum and have been looking into designing a project that uses a hall effect sensor to measure AC current, (50hz 240v mains AC)
    the sensor i have got is CSLA2CD
    and has the following datasheet:
    http://pdf1.alldatasheet.com/datashe...C/CSLA2CD.html
    the sensor can measure upto 72Amps, and has a linear output that will basically track the input waveform eg. AC voltage output
    the device outputs half the supply voltage at 0amps, and the output range is 25-75% of the supply voltage.
    The range of current i wish to measure is 0 - 50amps
    I think the easier solution is to convert the AC voltage to a DC level
    Does anyone have a circuit diagram that can inferface the sensor with the A/D input of a PIC eg PIC16F872?
  1. Circuit Diagram for interfacing AC to PIC IC?
    By wellyboot in forum Schematics
    Last Post: - 8th March 2008, 20:40
  2. How to read AC mains with an inductance coil
    By KB3BYT in forum mel PIC BASIC Pro
    Last Post: - 20th February 2008, 13:02
  3. Need Help On Ac Voltmeter !!
    By uludere72 in forum mel PIC BASIC Pro
    Last Post: - 17th July 2006, 00:36
  4. Special Offer AC -AC adapter
    By lester in forum Adverts
    Last Post: - 9th September 2005, 08:52
  5. Detecting AC current
    By rhino in forum Off Topic
    Last Post: - 8th July 2005, 22:31
