IR Remote Control
Results 1 to 3 of 3
    Jun 2006
    Talking IR Remote Control
    I have a panasonic TV remote control. Since the remote hanset itself has so many buttons, i plan to simplify it by creating a simple handset that only contain -> ( on/off, channel up, channel dn, volume up, volume dn ).
    i used 40KHz IR decoder to remove the carrier and use PIC to capture the data into the memory, it just don't work ! the TV doesn't respond !
    Any better idea ?
    Quote Originally Posted by mychangl View Post
    Any better idea ?
    Are you modulating a 40KHz signal with that data on your homemade unit? Or are you only sending data without a carrier frequency?
    Feb 2005
    Kolkata-India
    Default Just how did you captured the data into memory
    IR remotes uses different types of protocols mainly manchester oriented. However I have seen some chinese remotes which uses a variable pulse duty scheme with hold data. I don't know how you decoded the signal in the first place but the below links can be of real help:
    http://www.piclist.com/images/boards/irwidget/index.htm
    http://home1.stofanet.dk/hvaba/fprc5rx/index.html
    Sougata
  1. Replies: 17
    Last Post: - 12th April 2014, 03:17
  2. Plz help in completing RC-5 IR remote lamp dimmer project
    By vu2iia in forum mel PIC BASIC Pro
    Last Post: - 3rd April 2008, 09:44
  3. IR Remote Control Issues
    Last Post: - 28th August 2007, 15:12
  4. No one-way approach to learning ir remote control frequencies
    By selbstdual in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2007, 14:26
  5. Remote control
    By Radiance in forum General
    Last Post: - 6th August 2003, 16:13
