Still Struggling with IF THEN
Results 1 to 12 of 12
    Jan 2006
    New Hampshire, USA
    Default Still Struggling with IF THEN
    I have an LED on GPIO.0, I want it to light when GPIO.1 is low. In this program the LED comes on for 1 second at the beginnig, goes off for 1/2 sec then comes on and stays on. It does not matter if GPIO.1 is high or low. How do I make it work only when GPIO.1 is low?
    rem device = 12F675
    high GPIO.0
    PAUSE 1000
    ANSEL = 0 'GPIO.0 TO GPIO.3 SET AS DIGITAL
    OPTION_REG = 0 'WEAK PULLUPS ENABLED
    GPIO = %00111110 'PORT GPIO.0 SET LOW INITIALLY
    WPU = %00110110 'SETS WEAK PULLUP ON DIGITAL INPUTS
    rem define variables
    time1 var byte: time2 var byte: time4 var byte: time8 var byte
    time var word
    LOW GPIO.0
    PAUSE 500
    IF NOT GPIO.1 THEN
    HIGH GPIO.0
    LOW GPIO.0
    malc-c's Avatar
    malc-c Guest
    The first thing that appears to me to be missing is the config settings for the device
    @ __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _BODEN_ON
    I would also suggest that you use external pullup resistors of around 10K rather than rely on the internal WPU
    Jan 2006
    New Hampshire, USA
    Thanks. the internal pullup seems to be working OK. I set the configuration at programming time, I thought that was sufficient?
    Default Just curious
    What if instead of
    IF NOT GPIO.1 THEN
    You use
    IF GPIO.1=0 THEN
    ? just curious to see if there's any difference
    picster
    malc-c's Avatar
    malc-c Guest
    I always find it good practice to set the config bits in the code..
    The following turns on an LED on GPIO.0 when GPIO.1 is grounded (external 10K pullup) - Hope it helps
    ANSEL = 0
    CMCON=7
    TRISIO = %101010
    LED    var GPIO.0
    IF GPIO.1=0 THEN
         LED=1
         LED=0
    goto main:
    Jan 2006
    New Hampshire, USA
    Quote Originally Posted by picster View Post
    What if instead of
    IF NOT GPIO.1 THEN
    You use
    IF GPIO.1=0 THEN
    picster
    Yes, I tried that, no difference.
    malc-c's Avatar
    malc-c Guest
    It may not be the most structured of codes, but this also demonstrates the IF...Then...Else option
    ANSEL=0
    CMCON=7
    TRISIO = %101010
    LED    var GPIO.0
    IF GPIO.1=0 THEN
    goto flash
    LED=0
    goto main:
    Flash:
    LED=1
    If GPIO.1=1 then main:
    LED=0
    goto flash:
    I think your original problem was in setting the PIC up as digital and turning off the analogue functions, hence the ANSEL and CMCON settings
    Wow... I'm only a newbie and I've managed to pass on some advice... maybe my status should change from newbie to novice
    Jan 2006
    New Hampshire, USA
    Quote Originally Posted by malc-c View Post
    ANSEL = 0
    CMCON=7
    TRISIO = %101010
    LED    var GPIO.0
    IF GPIO.1=0 THEN
         LED=1
         LED=0
    goto main:
    Thanks, that works, now if I can work it into my program! I think the thing that makes it work is CMCON=7. I tried that earlier but misspelled it so got an error.
    Jan 2006
    New Hampshire, USA
    The IF THEN statements compile OK if I comment out the TRISIO line. The error message is: Warning line 15: $111110 numeric overflow. TRISIO never gave me a problem before, what is wrong?
    rem device = 12F675
    CMCON = 7
    TRISIO = $111110 'GPIO.0 SET AS OUTPUT, ALL OTHERS INPUT
    GPIO = %111110 'PORT GPIO.0 SET LOW INITIALLY
    WPU = %110110 'SETS WEAK PULLUP ON DIGITAL INPUTS
    time var word
    IF GPIO.1 = 0 THEN
    time1 = 1
    TIME1 = 0
    malc-c's Avatar
    malc-c Guest
    Quote Originally Posted by Russ Kincaid View Post
    Needs to be % not $
    try
    TRISIO = %111110
    Jan 2006
    New Hampshire, USA
    Thanks, I should have noticed that!
    My program runs now, not quite right yet, but I am getting there.
    malc-c's Avatar
    malc-c Guest
    Excellent... the 12F675 can be a finiky thing to configure right... especially for us newbies
  1. calculator-like code entry with matrix keypad and display
    By Dennis in forum mel PIC BASIC Pro
    Last Post: - 16th December 2009, 23:58
  2. Old analog guy needs help with PIC16F57
    By yankee in forum mel PIC BASIC Pro
    Last Post: - 6th March 2009, 14:32
  3. Replies: 5
    Last Post: - 28th June 2006, 22:32
