Still Struggling with IF THEN
Results 1 to 12 of 12
    Jan 2006
    New Hampshire, USA
    Quote Originally Posted by malc-c View Post
    I always find it good practice to set the config bits in the code..
    The following turns on an LED on GPIO.0 when GPIO.1 is grounded (external 10K pullup) - Hope it helps
    @ __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _BODEN_ON
    ANSEL = 0
    CMCON=7
    TRISIO = %101010
    LED    var GPIO.0
    IF GPIO.1=0 THEN
         LED=1
         LED=0
    goto main:
    Thanks, that works, now if I can work it into my program! I think the thing that makes it work is CMCON=7. I tried that earlier but misspelled it so got an error.
    Jan 2006
    New Hampshire, USA
    The IF THEN statements compile OK if I comment out the TRISIO line. The error message is: Warning line 15: $111110 numeric overflow. TRISIO never gave me a problem before, what is wrong?
    rem device = 12F675
    CMCON = 7
    ANSEL = 0 'GPIO.0 TO GPIO.3 SET AS DIGITAL
    OPTION_REG = 0 'WEAK PULLUPS ENABLED
    TRISIO = $111110 'GPIO.0 SET AS OUTPUT, ALL OTHERS INPUT
    GPIO = %111110 'PORT GPIO.0 SET LOW INITIALLY
    WPU = %110110 'SETS WEAK PULLUP ON DIGITAL INPUTS
    rem define variables
    time1 var byte: time2 var byte: time4 var byte: time8 var byte
    time var word
    IF GPIO.1 = 0 THEN
    time1 = 1
    TIME1 = 0
    malc-c's Avatar
    malc-c Guest
    Quote Originally Posted by Russ Kincaid View Post
    Needs to be % not $
    try
    TRISIO = %111110
    Jan 2006
    New Hampshire, USA
    Thanks, I should have noticed that!
    My program runs now, not quite right yet, but I am getting there.
    malc-c's Avatar
    malc-c Guest
    Excellent... the 12F675 can be a finiky thing to configure right... especially for us newbies
  1. calculator-like code entry with matrix keypad and display
    By Dennis in forum mel PIC BASIC Pro
    Last Post: - 16th December 2009, 23:58
  2. Old analog guy needs help with PIC16F57
    By yankee in forum mel PIC BASIC Pro
    Last Post: - 6th March 2009, 14:32
  3. Replies: 5
    Last Post: - 28th June 2006, 22:32
