I2CWRITE on a 24LC512
Results 1 to 18 of 18
    Mar 2007
    Post I2CWRITE on a 24LC512
    Hi all,
    i've some problems writing with I2CWRITE to this EEPROM (24LC512), it's wired to the PIC and pulled up via two 4.7k res.
    The pic sometime write, sometime not, this is the code:
    'Dichiaro le variabili
    W0 VAR WORD 'Memorizzazione I2C
    SCL VAR PORTC.3 'Pin per la memoria I2C Clock
    SDA VAR PORTC.4 'Pin per la memoria I2C Data
    I VAR WORD 'Generica
    Control VAR BYTE 'Costante byte di controllo EEPROM
    Control = $A0 'Imposto il byte di controllo
    OPTION_REG = %11101111
    'Imposto la frequenza di oscillazione a 10 Mhz
    DEFINE OSC 10
    'Imposto le porte della PIC
    TRISA = %11111111 'PortA Tutti input
    TRISD = %11111111 'PortD Tutti input
    TRISB = %00000001 'PortB Tutti output a parte 0
    PORTB = %00000000 'PortB Tutti low
    TRISC = %00000000 'PortC Tutti output
    PORTC = %00000000 'PortC Tutti low
    'Inizializzo l'EEPROM
    EEPROMInit:
    W0 = $0
    for I = 0 to $18
    I2cwrite SDA,SCL,CONTROL,I,[W0]
    pause 10
    next
    in the initial state where all the addresses is FFFF, after i use this code i can see this state in the EEPROM:
    0000: 1100 00FF 0000 0000 | ........
    0008: 0000 FF11 0000 FF11 | ........
    0010: FFFF FFFF FFFF FFFF | ........
    0018: FFFF FFFF FFFF FFFF | ........
    0020: FFFF FFFF FFFF FFFF | ........
    0028: FFFF FFFF FFFF FFFF | ........
    0030: FFFF FFFF FFFF FFFF | ........
    Can you help me solving this problem?
    Thank you,
    Luca
    EDIT:
    I'm using a PIC16F877A
    Last edited by oslinux; - 21st March 2007 at 17:49. Reason: Forget to write the PIC i'm using
    Feb 2005
    Kolkata-India
    Default Address inputs of the EEPROM ?
    The EEPROM you mentioned has address inputs on pins 1 and 2. Hope you have tried them to ground and not floating.
    BTW this EEPROM supports page write mode. That is you can dump 128 bytes of data to the EEPROM and wait 10mS rather than waiting 10mS for every byte.
    Sougata
    Perhaps you forget "DEFINE I2C_SLOW 1"
    Ciao
    oslinux, You don't need the "DEFINE I2C_SLOW 1" statement as the normal speed of this EEPROM is 400Khz.
    Mar 2007
    No way, it's always writing the 90% (or less) of what it should...
    oslinux, Try replacing the 4.7k pullups with 2.2k. Also, what are you doing with A0,A1, and A2 hardware address pins?
    Mar 2007
    A0, A1, A2 and WP are grounded, same problem with the 2.2K resistors, only some address are writed.
    Quote Originally Posted by oslinux View Post
    Can you get rid of the 24LC512 and try a 24LC256 instead, or at least a smaller eeprom chip?
    Not that it would make a difference...but it might...ya never know.
    Only reason I mention it is because lots of people have used (are using) the '256, don't think I've heard of anybody using a '512 yet. They are a bit on the new-ish side (2-3 years old I'd guess, maybe...maybe not).
    Also, try writing the whole eeprom, start to finish, try all $00's, try all $ff's, try a few things in between. There will probably be some sort of failure pattern in the eeprom readback itself that we might be able to see from a dump from the chip that'll narrow down the problem.
    Mar 2007
    Tried with the 256, and it does the same, i mean it does not write everything, anyway i have to use a 512, and when i will get my sample from microchip i will test the 1025, that's because i need more than 256k :S
    Note that the 64 do the same thing...
    Now i've put the whole thing in PROTEUS ISIS and i'v having the same problem, but i can see the log of the eeprom:
    212.727201m [RX_CMD     ]: Command received: 0xA0 (0b10100000). Device=0, Block=0x00, Address=0x0006 RD/WR=Write.
    223.593601m [RX_CMD     ]: Command received: 0xA0 (0b10100000). Device=0, Block=0x00, Address=0x0007 RD/WR=Write.
    234.460001m [RX_CMD     ]: Command received: 0xA0 (0b10100000). Device=0, Block=0x00, Address=0x0008 RD/WR=Write.
    245.326801m [RX_CMD     ]: Command received: 0xA0 (0b10100000). Device=0, Block=0x00, Address=0x0009 RD/WR=Write.
    256.192801m [RX_CMD     ]: Command received: 0xA0 (0b10100000). Device=0, Block=0x00, Address=0x000A RD/WR=Write.
    Until Here it's all good, but...
    256.708801m [RX_CMD     ]: Command received: 0xEE (0b11101110). Device=7, Block=0x00, Address=0x0009 RD/WR=Write.
    256.708801m [RX_CMD     ]: Unknown command value (0xEE) received - command is ignored.
    266.934401m [RX_CMD     ]: Command received: 0xA0 (0b10100000). Device=0, Block=0x00, Address=0x0009 RD/WR=Write.
    267.134001m [RX_CMD     ]: Command received: 0x0A (0b00001010). Device=5, Block=0x00, Address=0x0026 RD/WR=Write.
    267.134001m [RX_CMD     ]: Unknown command value (0x0A) received - command is ignored.
    277.362001m [RX_CMD     ]: Command received: 0xEE (0b11101110). Device=7, Block=0x00, Address=0x0026 RD/WR=Write.
    277.362001m [RX_CMD     ]: Unknown command value (0xEE) received - command is ignored.
    Here it comes, it can't recognize the commands because for example, instead of receive this control byte:
    0b10100000
    it receive this:
    0b00001010
    or this:
    0b11101110
    it's like there's something missing, the eeprom don't receive the whole bytes, maybe the 10MHz OSC is not good?
    Thx...
    Luca
    oslinux , I have used the 24lc512, 24lc515, 24lc1025 in pairs, to date with out any problem. One thing I did find is that if you are running interrupts during the read or write process I would sometimes have incorrect data ether read or written to the EEPROM. I disable all interrupts during the write process and I haven't had any problems since....
    Mar 2007
    no i'm not using interrupts, but aniway i've placed a DISABLE before the write...
    Try to split the word in 2 bytes;
    i2cwrite Sda,Scl,Ctrw,Addr,[TmpW.highbyte]
    pause 10
    Addr = Addr + 1
    i2cwrite Sda,Scl,Ctrw,Addr,[TmpW.lowbyte]
    pause 10
    Addr = Addr + 1
    Ciao
    Bombay, India
    Hoping all is well with the hardware, you need to break the addr part into 2 bytes.
    I2cwrite SDA,SCL,CONTROL,I.HighByte, I.LowByte, [W0]
    I use this in my design and it works correctly with a 24c512
    Jerson
    Mar 2007
    Solved Solved Solved Solved
    i tried splitting the address in two with no success, but
    i changed the resistors from 0,5W to 0,125W, from 2.2K to 4.7K and now it's working well!
    Thank you all for your support!
    Luca
    it make no real sense but if it's working...
    How many years/decade/century your Proto-Board (breadboard) have?
    Mar 2007
    it's a breadboard from 4 years ago if i remember well, but it has been used for a lot of projects, and not only with wires of the right width!
    I'll use my new proto-board in a better way, I PROMISE
    Yeah i see... We all tried to fit over-rated Awg wires + few TO-3 working on +/- 80 VDc and/or 110/220 VAC on those gizmuth
    This remind me few plastic smells experiments...
    Or used a proto-board without the double-sided protective sticky tape on the back and decided it would be a good idea to lay the board down onto something electrically conductive?
    Smoke, sparks, melted pieces/parts, popped circuit breakers, blown fuses, all sorts of fun!!!
  1. I2CRead & I2CWrite not working as expected
    Last Post: - 27th October 2021, 18:36
  2. PIC 18F4550 and MCP23017
    By DaveC3 in forum Code Examples
    Last Post: - 4th December 2010, 14:01
  3. Puzzling issue with I2CWRITE to 24LC512
    By aberco in forum General
    Last Post: - 22nd August 2008, 17:47
  4. My I2CWRITE - timings and tricks
    By FinchPJ in forum Code Examples
    Last Post: - 3rd March 2008, 21:40
  5. I2CWRITE and I2CREAD
    By Tomas in forum mel PIC BASIC Pro
    Last Post: - 23rd April 2004, 02:30
