Serin Problem 16f819
Results 1 to 4 of 4
    Mar 2007
    This code was taken from larger code. I just wanted to isolate the serin and serout commands. that is why some of the configuration lines are still in the code. What is LVP mode? You say that you cannot run 9600 baud w/ a 4MHz crystal. Would this also apply to serout, because I have had no problems with that at all.
    Don't use SERIN/SEROUT/SERIN2/SEROUT2 @ 9600 bauds @ 4MHZ. DEBUG may work better. BUT HSERIN/HSEROUT will works a treat... on the right pins.
    Use the PicMultiCalc to generate the right HSERIN/HSEROUT DEFINEs
    http://www.mister-e.org/pages/utilitiespag.html
    LVP mode HAVE TO BE DISABLED.
  1. Serin Problem with 12F629/PBP
    By Flyingms in forum mel PIC BASIC Pro
    Last Post: - 9th March 2009, 15:59
  2. Serin serout problem
    Last Post: - 6th February 2007, 05:25
  3. Problem with PBP interrupt and Serin, please help
    By rgregor in forum mel PIC BASIC
    Last Post: - 22nd August 2006, 20:02
  4. serout and serin problem
    Last Post: - 11th April 2006, 20:44
  5. 16F877A serin problem with baud rate 19200
    By leemin in forum Serial
    Last Post: - 31st July 2005, 10:45
