if then problem
Results 1 to 4 of 4
Thread: if then problem
    You can't put the else part on the same line as the IF.
    It should look like...
    if not GPIO.1 then
        time1 = 1
        time1 = 0
    But then, all you are really doing is inverting the bit, so you could do this.
    time1 = GPIO.1 ^ 1
    time2 = GPIO.2 ^ 1
    time3 = GPIO.3 ^ 1
    time4 = GPIO.4 ^ 1
    OR, you could do them all at once if the variables are setup right.
    time    VAR BYTE
      time1 VAR time.1
      time2 VAR time.2
      time3 VAR time.3
      time4 VAR time.4
    time = GPIO ^ %11110
    Jan 2006
    New Hampshire, USA
    Thanks, I can see I have a lot to learn. What is that carot thingy doing? If GPIO is high, does it make it low and vice versa?
    Quote Originally Posted by Russ Kincaid View Post
    Hi Russ,
    see page 36 section 4.17.14 Bitwise Operators
    JS
  1. problem using GOSUB under interrupt
    By fobya71 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2010, 19:52
  2. USART Problem , but don't know where, in pc? or in PIC?
    Last Post: - 15th July 2007, 08:12
  3. Microcode Studio 18f2455 problem?????
    By volkan in forum mel PIC BASIC Pro
    Last Post: - 21st May 2007, 21:04
  4. Hardware problem or what ?
    By Steve S. in forum mel PIC BASIC Pro
    Last Post: - 4th March 2007, 21:39
  5. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 22:59
