if then problem
Results 1 to 4 of 4
Thread: if then problem
    Jan 2006
    New Hampshire, USA
    Default if then problem
    This has got to be simple but I can't see the problem. This is my code:
    if not GPIO.1 then time1 = 1 else time1 = 0
    IF not GPIO.2 THEN time2 = 2 else time2 = 0
    IF not GPIO.3 THEN time4 = 4 else time4 = 0
    if not GPIO.4 then time8 = 8 else time8 = 0
    The compiler error is: bad expression or missing THEN
    I tried putting colons in it even tho the manual doesn't say they are needed, but that was no help.
    Hmmm, I copied an IF THEN out of the manual and ran it thru the compiler, same error. What's up?
    Russ
    You can't put the else part on the same line as the IF.
    It should look like...
    if not GPIO.1 then
        time1 = 1
        time1 = 0
    But then, all you are really doing is inverting the bit, so you could do this.
    time1 = GPIO.1 ^ 1
    time2 = GPIO.2 ^ 1
    time3 = GPIO.3 ^ 1
    time4 = GPIO.4 ^ 1
    OR, you could do them all at once if the variables are setup right.
    time    VAR BYTE
      time1 VAR time.1
      time2 VAR time.2
      time3 VAR time.3
      time4 VAR time.4
    time = GPIO ^ %11110
    Jan 2006
    New Hampshire, USA
    Thanks, I can see I have a lot to learn. What is that carot thingy doing? If GPIO is high, does it make it low and vice versa?
    Quote Originally Posted by Russ Kincaid View Post
    Hi Russ,
    see page 36 section 4.17.14 Bitwise Operators
    JS
  1. problem using GOSUB under interrupt
    By fobya71 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2010, 20:52
  2. USART Problem , but don't know where, in pc? or in PIC?
  3. Microcode Studio 18f2455 problem?????
    By volkan in forum mel PIC BASIC Pro
    Last Post: - 21st May 2007, 22:04
  4. Hardware problem or what ?
    By Steve S. in forum mel PIC BASIC Pro
    Last Post: - 4th March 2007, 22:39
  5. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 23:59
