I2CWRITE on a 24LC512
Results 1 to 18 of 18
    oslinux, Try replacing the 4.7k pullups with 2.2k. Also, what are you doing with A0,A1, and A2 hardware address pins?
    Mar 2007
    A0, A1, A2 and WP are grounded, same problem with the 2.2K resistors, only some address are writed.
    Quote Originally Posted by oslinux View Post
    Can you get rid of the 24LC512 and try a 24LC256 instead, or at least a smaller eeprom chip?
    Not that it would make a difference...but it might...ya never know.
    Only reason I mention it is because lots of people have used (are using) the '256, don't think I've heard of anybody using a '512 yet. They are a bit on the new-ish side (2-3 years old I'd guess, maybe...maybe not).
    Also, try writing the whole eeprom, start to finish, try all $00's, try all $ff's, try a few things in between. There will probably be some sort of failure pattern in the eeprom readback itself that we might be able to see from a dump from the chip that'll narrow down the problem.
    Mar 2007
    Tried with the 256, and it does the same, i mean it does not write everything, anyway i have to use a 512, and when i will get my sample from microchip i will test the 1025, that's because i need more than 256k :S
    Note that the 64 do the same thing...
    Now i've put the whole thing in PROTEUS ISIS and i'v having the same problem, but i can see the log of the eeprom:
    212.727201m [RX_CMD     ]: Command received: 0xA0 (0b10100000). Device=0, Block=0x00, Address=0x0006 RD/WR=Write.
    223.593601m [RX_CMD     ]: Command received: 0xA0 (0b10100000). Device=0, Block=0x00, Address=0x0007 RD/WR=Write.
    234.460001m [RX_CMD     ]: Command received: 0xA0 (0b10100000). Device=0, Block=0x00, Address=0x0008 RD/WR=Write.
    245.326801m [RX_CMD     ]: Command received: 0xA0 (0b10100000). Device=0, Block=0x00, Address=0x0009 RD/WR=Write.
    256.192801m [RX_CMD     ]: Command received: 0xA0 (0b10100000). Device=0, Block=0x00, Address=0x000A RD/WR=Write.
    Until Here it's all good, but...
    256.708801m [RX_CMD     ]: Command received: 0xEE (0b11101110). Device=7, Block=0x00, Address=0x0009 RD/WR=Write.
    256.708801m [RX_CMD     ]: Unknown command value (0xEE) received - command is ignored.
    266.934401m [RX_CMD     ]: Command received: 0xA0 (0b10100000). Device=0, Block=0x00, Address=0x0009 RD/WR=Write.
    267.134001m [RX_CMD     ]: Command received: 0x0A (0b00001010). Device=5, Block=0x00, Address=0x0026 RD/WR=Write.
    267.134001m [RX_CMD     ]: Unknown command value (0x0A) received - command is ignored.
    277.362001m [RX_CMD     ]: Command received: 0xEE (0b11101110). Device=7, Block=0x00, Address=0x0026 RD/WR=Write.
    277.362001m [RX_CMD     ]: Unknown command value (0xEE) received - command is ignored.
    Here it comes, it can't recognize the commands because for example, instead of receive this control byte:
    0b10100000
    it receive this:
    0b00001010
    or this:
    0b11101110
    it's like there's something missing, the eeprom don't receive the whole bytes, maybe the 10MHz OSC is not good?
    Thx...
    Luca
    oslinux , I have used the 24lc512, 24lc515, 24lc1025 in pairs, to date with out any problem. One thing I did find is that if you are running interrupts during the read or write process I would sometimes have incorrect data ether read or written to the EEPROM. I disable all interrupts during the write process and I haven't had any problems since....
    Mar 2007
    no i'm not using interrupts, but aniway i've placed a DISABLE before the write...
    Try to split the word in 2 bytes;
    i2cwrite Sda,Scl,Ctrw,Addr,[TmpW.highbyte]
    pause 10
    Addr = Addr + 1
    i2cwrite Sda,Scl,Ctrw,Addr,[TmpW.lowbyte]
    pause 10
    Addr = Addr + 1
    Ciao
  1. I2CRead & I2CWrite not working as expected
    Last Post: - 27th October 2021, 18:36
  2. PIC 18F4550 and MCP23017
    By DaveC3 in forum Code Examples
    Last Post: - 4th December 2010, 14:01
  3. Puzzling issue with I2CWRITE to 24LC512
    By aberco in forum General
    Last Post: - 22nd August 2008, 17:47
  4. My I2CWRITE - timings and tricks
    By FinchPJ in forum Code Examples
    Last Post: - 3rd March 2008, 21:40
  5. I2CWRITE and I2CREAD
    By Tomas in forum mel PIC BASIC Pro
    Last Post: - 23rd April 2004, 02:30
