error message
Results 1 to 6 of 6
Thread: error message
    Default ok
    that seems to be the problem but i dont want to use pbp out of dos
    any way to set this in mcs/pbp windows
    i guess every body is aware that dos is dieing a much deserved death
    [ boy that will get a responce ]
    another point error does not occur when not useing mpasm but was using mpsam because of another error page crossing which apparently will someday be fixed in pbp (hope so)
    also really hard to believe my pc is low on memory has 2 gb
    Quote Originally Posted by jcleaver View Post
    In the PBP manual, something about adding files, stacks and buffers to the ol' config.sys file...don't have the manual handy, can't remember right now. Might help though...
    Got it now...
    Page 5 of the PBP manual. Might help out depending on your PC's configuration. Of course, that's only going to work if it's a Windows problem.
    If the problem is that you've allocated too much ram, or have a program that's just too large, then that's another ball game entirely...
