Originally Posted by
syscoder
hi friends i search in the forum and found many examples thanks.
You also appear to have MANY POSTS.
Why post the same thing in three threads in the same forum ?????
I didnt read the whole of your code but just this bit is flawed.
So at this point you are reading a lighting level 00-FF (0-255) into a variable called "level1"
portC.1 = level1 'i want to dimm led on port c.1
Now you try to assign a byte size variable to a single BIT of an output port which can only ever be 0 or 1, OFF or ON.
It has been stated several times that you need to create a PWM signal to DIM your LEDs. You need to read up on how to do that. Plenty of examples all over the forum and the wider Internet.
Keith
www.diyha.co.uk
www.kat5.tv
