Convert an integer to a string
Results 1 to 6 of 6
    How about:
    Serout......[#var_name]
    LCDOUT $FE,1,[#var_name]
    /Henrik Olsson.
    Perhaps i badly explained.
    I do not use serout or lcdout; i need a 16 bit binary to decimal conversion; i have to send a variable value to the Nokia 3310 display.
    I now realized that DIG may be useful.
    Bombay, India
    Hmm.. you are looking for an equivalent like the c function sprintf.
    You are right, the DIG command is ideal to build the string. It may be more optimised if you hand code in asm
    Jerson
    Quote Originally Posted by GioppY View Post
    tenthousands = value / 10000
    value = value - ( tenthousands * 10000 )
    value = value - ( thousands * 1000 )
    hundreds = value / 100
    value = value - ( hundreds * 100 )
    tens = value / 10
    value = value - ( tens * 10 )
    ones = value
    string(4) = tenthousands + 48
    string(3) = thousands + 48
    string(2) = hundreds + 48
    string(1) = tens + 48
    string(0) = ones + 48
    First chunk of code will get the decimal values for the place holder for that digit.
    Second chunk of code will change that into an ASCII representation of that number.
    Then you can just serout (or SPI or I2C or whatever) that 'string' out whatever port you need to...
    Theoretically anyways...
  1. How about String Variables?
    By mytekcontrols in forum PBP Wish List
    Last Post: - 20th January 2015, 13:53
  2. How to convert a HSERIN string to a hex value?
    By ShortBus in forum mel PIC BASIC Pro
    Last Post: - 22nd October 2009, 05:41
  3. Replies: 11
    Last Post: - 12th July 2008, 03:36
  4. How to convert HEX Value as formatted BIN String ?
    By Robson in forum mel PIC BASIC Pro
    Last Post: - 19th August 2007, 03:16
  5. Visual Basic 6 & Access 2000
    By Demon in forum Off Topic
    Last Post: - 7th September 2006, 05:39
