always go to interrupt
Results 1 to 3 of 3
    Jun 2006
    Default always go to interrupt
    i have a problem with below code.
    always go to interrupt.Why;
    i use pic16f88
    i have pull-ups resistors to rb4-rb7
        INTCON = %10001000          ' %10001000  enable interrupts on RB4 through RB7
        SW1 var PORTB.4
        SW2 var PORTB.5
        SW3 var PORTB.6
        SW4 var PORTB.7
        LED1 var PORTA.0
        LED2 var PORTA.1
        On Interrupt goto inter    ' Define interrupt handler
        TRISA=%11110000         'PA3-PA0=output
        TRISB=%11110000         'PB7-PB4=input, PB3-PB0=output
        PORTA=0                 'Turn off all LEDs
    Loop:
        High PORTA.0
        Pause 500
        Low PORTA.0
        Pause 500
        goto Loop
         Disable                ' No interrupts past this point
    inter:
    '*** Blinking routine ***
        High PORTA.0
        Pause 500
        Low PORTA.0
        Pause 500
        High PORTA.1
        Pause 500
        Low PORTA.1
        Pause 500
        INTCON.0=0       ' Clear interrupt flag
        Resume           ' Return to main program
        Enable
    Section 5.2 of the 16F88 datasheet, mainly the 3rd paragraph
    Feb 2005
    Kolkata-India
    Default Check this out
    You need to use INTCON = $80 to clear interrupt flags. Also the portb mismatched condition is cleared when you read it.
    Sougata
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 10:00
  2. Can't ID interrupt source with this IntHandler??
  3. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 19:14
  4. NEWBIE: Some basic questions using interrupts
    By JackPollack in forum mel PIC BASIC Pro
    Last Post: - 8th March 2006, 03:59
