16F876 Usart Receive
Results 1 to 8 of 8
    level1 = RCREG
    portC.1 = level1 'i want to dimm led on port c.1
    RCSTA.7 = 0
    What exactly is the line above supposed to accomplish? and/or what is portC.1 doing for you with the above program?
    Mar 2007
    Default dmx
    thanks.
    portc.1 is for the led i will make a led dimmer.(0-255 = %0 -%100 intensty)
    but there is some problem on the code i think.
    I do not see RCREG defined as a variable.
    Mar 2007
    Default dmx
    thanks for your qick answer friend .
    i was looking for a example code in this forum and saw many examples and wanted to make it for my pic 16F876 i have forund that code here in the forum and it was and also they said that it is working code.but can you say where is my problem on that code it is not working
    http://www.picbasic.co.uk/forum/show...ghlight=dmx%2A
    Feb 2005
    Kolkata-India
    Default You did not answer skimask
    level1 = RCREG
    RCSTA.7 = 0
    RCREG is the hardware USART receive register (SFR). You are trying to dump its value (dimming value) to a Port PIN C.1 . You should use a PWM to achieve this. Your checkdmx routine waits for a valid address and then grabs the byte being received. Use the Hardware PWM unit to make your life easier.
    Sougata
    Mar 2007
    Default dmx
    thanks for answer and can you say me how to use it ? i dont know cause ima new user on pbp
    Quote Originally Posted by syscoder View Post
    thanks.
    You do know that you aren't going to dim anything using just portc.1 and turning it on and off. You have to use a PWM output or some sort of software driven PWM...change the duty cycle. Just sending the intensity (0-255, a byte value) to portc.1 (a bit value) isn't going to do anything for you...
    And I'm done answering your multiple questions in multiple forums about the same thing...
  1. How to receive stream of bytes using PIC USART
    By unifoxz in forum mel PIC BASIC Pro
    Last Post: - 20th June 2009, 10:38
  2. Replies: 6
    Last Post: - 31st August 2007, 09:31
  3. problem with USART
    By leemin in forum Serial
    Last Post: - 11th December 2006, 17:56
  4. USART interrupt not interrupting right
    Last Post: - 6th March 2005, 01:07
  5. receive ASCII with usart
    By harryweb in forum mel PIC BASIC Pro
    Last Post: - 9th February 2004, 08:57
