XOUT translates the codes to be compatible with the BS2. (ugg)
If you use ...It turns off the translation, then you can use the codes from the table you were refering to.Code:DEFINE XOUTXLAT_OFF 1
Note: All the ON/OFF etc. codes will be different too.
