Erasecode,Writecode,Readcode - again
Results 1 to 15 of 15
    OK, after those results, I'm compelled to go out on a limb.
    That limb is to say that...
    1. PBP is wrong, by declaring BLOCK_SIZE as 64 bytes. But I can't blame them, because....
    2. Microchip is wrong, since their datasheet says the Flash must be written 64 bytes at a time.
    It seems apparent that the 18F8722 only has 8 holding registers for flash writes (regardless of what the datasheet says). It does erase 64 bytes at once. But you can only write 8 bytes at a time. Coincidently, that's the same as the 18F8720, it's predecessor.
    I may be eating crow by the next post. But I'm pretty sure this will work...
    AA VAR WORD
    BB VAR WORD
    CC VAR WORD
    DD VAR WORD
     X VAR BYTE
    ERASECODE $1F00
    TBLPTRU = 0
    TBLPTRH = $1F
    TBLPTRL = 0
    for X = 0 to 7
        gosub Write8
    next X
    Gosub ShowFlash
    stop
    ;_____________________________________________
    Write8:
        For BB = 0 to 7
            TABLAT = BB.Lowbyte
            @ tblwt*+
        NEXT BB
        TBLPTRL = TBLPTRL - 1
        EECON1 = $84
        EECON2 = $55
        EECON2 = $AA
            bsf   EECON1, WR
            nop
            bcf   EECON1, WREN
        endasm
        TBLPTRL = TBLPTRL + 1
    ShowFlash:
        For CC = $1F00 to $1F3F STEP 2
            READCODE CC,DD
            HSEROUT [HEX4 CC," ",HEX4 DD,13,10]
        NEXT CC
        HSEROUT [10]
    Then, assuming that works. Simply changing BLOCK_SIZE EQU 64 to, BLOCK_SIZE EQU 8 in the 18F8722.INC file should fix it.
    The only thing I have here to test it on is an 18F6720, which is also Erase 64/write 8. And it works here....
    Prepare to feed me my Crow.
    Sep 2005
    Campbell, CA
    WORKS!
    Thanks again!
    Anybody from Microchip out there listening? You owe Darrel at least a dinner!
    Charles Linquist
    Quote Originally Posted by Charles Linquis View Post
    WORKS!
    Thanks again!
    And I have to wonder how and why my PICKIT2 works with the '8722 if it's actually using the datasheet specifications.
    Apparently, Microchip is holding out on the datasheet info and/or revisions/errata again...
    WORKS!
    Oh thank God!
    It's always so hard to get the feathers out of my teeth.
    Sep 2005
    Campbell, CA
    Thanks to a mis-labeled board (it actually had an 8720 on it, rather than an 8722), I really got things screwed up.
    And it turns out that MC's documentation is indeed correct - the 8720 has a block size of 8 bytes, while the 8722 has a block size of 64 bytes.
    Everything is working now. I *would* let Darrel feed me some of that crow, but I'm a vegetarian !
    Charles Linquist
    Default Omg!
    And let that be a lesson to everyone.
    Never trust your test equipment unconditionally.
    Especially when it's not electronic.
    Ok well, I suppose I'll have a few feathers for dinner, but I can see you're not going to chow down willingly, mr vegan. So just to make sure, I've put a heaping helping in your avatar.
    I'll trade ya some spaghetti for some of that crow
    Spaghetti sounds good.
    But some floss for the feathers would be better.
    Apr 2010
    Walnut Creek, CA
    Default Re: Erasecode,Writecode,Readcode - again
    Good golly, this works. I fussed around with PBP WRITECODE for way too long and gave up, modified Darrel's code slightly, and it works! Here's my code. Thanks Darrel!
    Code for PIC18F8722:
    FOR IX = 0 TO 63 ' for DEBUG
    FLASH_WRITE_BUFF[IX] = IX + 64 ' for DEBUG
    NEXT IX ' for DEBUG
    ' DEBUG WRITE FLASH PROGRAM MEM TEST
    ERASECODE FLASH_MEM_START
    FOR IX = 0 TO 63 ' load TBLAT
    TABLAT = FLASH_WRITE_BUFF[IX]
    @ tblwt*+
    NEXT IX
    TBLPTRL = FLASH_MEM_START
    EECON1 = $84
    EECON2 = $55
    EECON2 = $AA
    BSF EECON1, WR
    NOP
    BCF EECON1, WREN
    ' DONE WRITING FLASH PROGRAM MEM TEST
