Pin outputs to an array
Results 1 to 2 of 2
    Jan 2007
    Default Pin outputs to an array
    I would like to associate 32 pins of my 18F4525 to an array such as ch_out[32]. I am having trouble getting anything to compile.
    This will not work:
    ch_out VAR BIT[32]
    ch_out[1] VAR PORTA.1
    This will not work:
    ch_out VAR BIT[32]
    SYMBOL ch_out[1] = PORTA.1
    This will not work:
    This will not work:
    ch1 VAR PORTA.1
    SYMBOL ch_out[1] = ch1
    This will not work:
    ch1 VAR PORTA.1
    ch_out[1] VAR ch1
    I want to process all the pins in one loop by incrementing a loop counter and turning the pin on or off using an IF THEN statement. For example:
    FOR cnt = 1 to 32
    IF ch_data[cnt] >= 1 THEN
    HIGH ch_out[cnt]
    LOW ch_out[cnt]
    NEXT cnt
    Anyone have a solution?
    See this ...
    Indexing Port Pins
    http://www.picbasic.co.uk/forum/showthread.php?t=3753
  1. Is this a K Type sensor?
    Last Post: - 21st November 2009, 14:55
  2. 8 pin DIP w/6 outputs ?
    By Sam in forum General
    Last Post: - 14th September 2009, 21:15
  3. DS1820 with 16f688
    Last Post: - 23rd May 2009, 06:07
  5. Another RTC, DS1287
    Last Post: - 12th December 2006, 18:07
