problems with USB programmer
Results 1 to 8 of 8
    malc-c's Avatar
    malc-c Guest
    Default problems with USB programmer
    Long story, but in a nutshell:
    Browsing e-bay I noticed a guy selling a USB PIC Programmer in kit form. He also stated that he could sell just the pre-programmed PIC and PCB's - so I e-mailed him for further details and it transpires that the programmer is in essence a GTP-USB-lite, but with his own PCB design. As I already had the files, including the HEX and drivers for this project I simply ended up purchasing the bare PCB.
    I've since constructed the programmer which, from component identification is based on the attached schematic (only differences are that he uses two LEDs rather than a bi-colour LED, the trannys are BC547's, and the timing caps are 22pf not 15pf as shown). Now comes the strange part.
    I hooked up the USB cable, the red LED (RB7) lit up and then went out as the green one (RB6) came on and windows found the new hardware, and on pointing it to the supplied drivers the installation was complete. It's listed in Device manager and there are no conflicts. So far so good !
    I then hooked up a 16F84a and connected the ISCP leads via a jumper cable. Launched the version of winpic800 (3.55g) that came with the files and selected the detect device - bingo it came back with "16F84A" - performed a hardware check and it found the programmer and reported all was OK. - Excellent I thought all seems to be working fine.....
    I then opened some hex for the target PIC and clicked on the program all button. It squirted the hex to the PIC so fast I hardly saw the progression bar (well its USB2 full speed device) - however it then got to 93% in varification and halted with an error - "No is answer of hardware" (the author is Spanish). From then on any attempt to communicate with the programmer results in the software not being able to open the driver, and I have to un-plug and re-plug in the programmer to reset it all.
    So I checked the voltages:
    Under normal conditions they are:
    Vpp - + 0.01v
    Vdd - +5.01v
    data - +0.03v
    clk - +0.02v
    Programing:
    Vpp - +13.88v
    Vdd - +5.00v
    data - +1.57v
    clk - +1.4v
    The strange thing is that once it's errored and even if you shut down the software, the programmer still retains the programming voltages.
    I've tried several pics and they all do the same.
    Does anyone have any ideas - or suggestions on things to try ? The fast replies from the vendor to my previous mails seemed to of stopped now..I'm hoping its just because he's gone out for the eveing, and not that he is ignoring my requests for advice !
    malc-c's Avatar
    malc-c Guest
    Sorted - turns out its my UBS ports as it works fine on my sons PC !!!
    Looks like a change of motherboard is in order
    Quote Originally Posted by malc-c View Post
    Just curious here...
    Did you try both front and rear USB ports?
    Front mounted USB ports are generally connected to a 'hub' on the motherboard, wheras rear mounted USB ports generally connect directly to the chipset (latency issues, don't ask me why, I just know it works out that way sometimes).
    malc-c's Avatar
    malc-c Guest
    Yes I tried all ports (2 headers on the MoBo and 2 sockets on the MoBo) and the same thing happens. I think its probably down to the nForce2 Ultra400 chipset.
    It will be a few days befor the new card arrives, but I'll let you know how I get on.
    Default Cost
    Hi Malc-c,
    Curious as to cost of this, and maybe you can give us a link to the seller?
    Does it perform now as expected?
    regards
    JS
    malc-c's Avatar
    malc-c Guest
    Joe, full details can be found at CT Tunings website (http://www.ct-tuning.co.uk)
    The cost is £19.99 for the kit
    It works great on my son's PC and supports a wide range of common PICs inc the more popular 18F series (like the 18F2550). It also programs chips that require special treatment of the vdd and vpp lines such as the 12F675.
    The Kit takes about an hour to build (may be less if you're a fast builder).
  1. Usb Programmer ?
    By iugmoh in forum USB
    Last Post: - 20th April 2008, 18:10
  2. USB programmer problem 18LF4620
    Last Post: - 8th November 2007, 02:03
  3. melabs usb programmer problem
    By bigbear in forum General
    Last Post: - 28th December 2006, 12:50
  4. USB programmer problems
    By uiucee2003 in forum USB
    Last Post: - 15th August 2006, 23:47
  5. Melabs USB Programmer
    By tmurph in forum General
    Last Post: - 25th December 2005, 03:25
