SERIN Timeout
Results 1 to 16 of 16
Thread: SERIN Timeout
    New Zealand
    Yeah, have written the code for the sender so can change that to whatever, I've got "READY" as my qualifier. I'm going to try your idea about using a very short timeout to see how it works 1-2ms I'm thinking at the moment - will be interesting if nothing else to see what effect it has on the time keeping. Thanks for all yr input so far
    Quote Originally Posted by George View Post
    I just saw that your baud rate is 2400. That's .416 us per bit, a start bit is generally 1.5 bit lengths, which gives you .625us for a start bit. Timeout is limited to 1 ms minimum, it might work, it might not. You might end up waiting for READY, but only able to receive "EADY". I would think if you sent a string of qualifiers (bunch of $AA55's or the like), say 10 of them, wait until you have a solid 5 received, then you should be able to dispense with any timeouts because you signal is strong enough to get the qual's.
    New Zealand
    I've got a string of 5 $AA preceeeding the READY, and haven't seemed to have much of a problem getting the data to the receiver - i send the data 5 times on a transmission to make fairly sure it gets through. I've got the timeout at 1ms toggling an LED to indicate to me when it's exiting out of the serin command - it's way random tho can tripout every half second or every 10 minutes. The issue I have is not so much transmitting the data - it's when no data is being transmitted
    New Zealand
    Oh the other thing I forgot to mention is that the RF modules r AM so there is alot of static when there is no carrier
    ooofff...AM...that hurts
    Still, send the data multiple times, add a checksum to the data, receive the data successfully X number of times, blah blah blah... Should be too much of a problem even with all that random AM static noise.
    But you're still on the problem of sitting in a SERIN loop waiting for solid data while you still need to do other stuff, correct? How about a 2nd PIC (say a 16F688) that just sits there and waits for data, and when it gets good data, it fires it out a different serial port to the 'real' PIC, which doesn't have to worry about garbage data... Heck, might even be a good spot for a 10F202 to handle that job!!!
    New Zealand
    Yah - I wanted to avoid something like that due to complexity - plus haven't had any luck with PBP and 10F202 (PBP uses up too many variables - tho for a simple job like that I'm sure it would work) electronically it's prolly simpler for me to build a squelch. I might do a new post with a title more reflecting ASM interupts - thanks for all yr input
    unless your module have a RSS output, send it to the trash can.
    Can you not install a squelch circuit on the receiver?
    Or feed it to a PIC comparator input
    Sorry if this sounds like a PMS reply but we still don't know which RF module you're using.
  1. Serin timeout not working properly!
    Last Post: - 1st January 2010, 21:56
  2. SERIN timeout
    By Del Tapparo in forum Serial
    Last Post: - 20th November 2007, 05:34
  3. 16F628A Serin timeout and Timer1
    Last Post: - 27th March 2006, 00:20
  4. SERIN SERIN2 Timeout
    By markedwards in forum mel PIC BASIC Pro
    Last Post: - 23rd June 2005, 19:59
  5. SERIN & Timeout
    By BigWumpus in forum mel PIC BASIC Pro
    Last Post: - 30th October 2004, 08:33
