serout
Results 1 to 11 of 11
Thread: serout
    Jun 2006
    the LED is blinking. i even put LED to monitor the serial output, it is flickering. Modem ground is connected to PIC gnd.
    neither
    SerOut Tx,t300,["ATH1"]
    SerOut Tx,t300,["ATH0"]
    SerOut Tx,t1200,["ATH1"]
    SerOut Tx,t2400,["ATH1"]
    SerOut Tx,t9600,["ATH1"]
    work, i not sure about line feed or carriage.There is no information about linefeed and carriage found in any modem articles, even hyperterminal doue not require that..
    Anyway, let me try
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Something to try - see if you can get your pic to talk to hyperterminal (using your max232 setup as is). This might help you determine if the problem is closer to the PIC side or closer to the modem side.
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Jun 2006
    Thumbs up
    Thanks guys. i got the code....
    it should has carriage return ( 13 ) after the command.
    SerOut Tx,t9600,[65,84,72,49] ' Off Hook ATH1'
    SerOut Tx,t9600,[13]
    now i am looking into more functions eg connect to other modem...
    Thx a lot !
    Cheeeeers
    Glad to hear you got it going!
    A little tip: Put the carriage return on the same line as the 'command'
    SerOut Tx,t9600,[65,84,72,49,13] ' Off Hook ATH1, CR
    Should work the same and you'll save a couple of bytes for each instance. Also Serout....["ATH1",13] should work the same but makes the code easier to understand, to me atleast....YMMV.
    Good luck with the project!
    /Henrik Olsson.
    Jun 2006
    Cool
    That is just the beginning...
    ["ATH1",13] work fine ! Thanks for all your suggestion.
    Last Post: - 8th March 2010, 21:58
  2. Serout to serial servo
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 12th August 2009, 17:46
    Last Post: - 13th December 2008, 18:11
  4. Keypad unlock (as in garage door possibly)
    By Fred in forum Code Examples
    Last Post: - 2nd April 2006, 05:26
  5. Replies: 11
    Last Post: - 13th July 2005, 20:26
