serout
Results 1 to 11 of 11
Thread: serout
    Jun 2006
    Angry serout
    Anyone out there can help me solve this problem ? i have been trying to get my pic 16F84 to control an external 33.6k serial modem.
    The modem work fine with hyperterminal. But it doesn't work with PIC.
    PortB.1 is connected to pin10 of MAX232 ( TTL in ) and MAX232 pin7 ( 232 out ) is connected to pin 3 of modem DB9.
    Pin 4 & 6 of DB9 is shorted ( DTR & DSR ).
    Pin7 & 8 of DB9 also shorted ( RTS & CTS )
    CODE SAMPLE :
    TRISB=%00000000 'PortB.0 & PortB.1 = output
    Dialing VAR PORTB.0 'Set PortB.0 as Dialing indicator
    Tx VAR PORTB.1 'Set PortB.1 as Transmit signal to modem
    PORTB=%00000000
    Pause 1000
    MAIN :
    High Dialing
    SerOut Tx,t300,[65,84,72,49] ' Off Hook ATH1
    Low Dialing
    What is the catch ????
    Mar 2005
    Iowa, USA
    Try...
    Include “modedefs.bas”
    The Mode names (e.g. T2400) are defined in the file MODEDEFS.BAS.
    To use them, add the line:
    to the top of the PicBasic Pro program. BS1DEFS.BAS and
    BS2DEFS.BAS already includes MODEDEFS.BAS. Do not include it again
    if one of these files is already included. The Mode numbers may be used
    without including this file.
    Wisdom is knowing what path to take next... Integrity is taking it.
    Ryan Miller
    Jun 2006
    modedefs.bas is included but still doesn't work...
    i also tried :
    1. inverted TTL N300 to N2400
    2. change Define Char_pacing 1000 to 10000
    however it still not working...
    What is the clock frequency and what do you use as the clock source? For serial communication to be reliable you really should use a X-tal. What baudrate did you set Hyperterminal to when testing the modem? 300baud?
    /Henrik Olsson.
    Jun 2006
    I use 4MHz resonator. i did use the same type of resonator before when i did a serial comm project between 2 remote PIC 16F84 at 1200baud.
    In Hyperterminal, i tried 300 baud, 1200 baud and 2400 baud. All working fine. The only difference i noticed with this baud rates is the speed and it is obvious when i type AT&V.
    A modem should detect the baud rate automatical isn't ?
    mychangl
    Generally you should be fine with the resonator. Are you sure that the PIC is running? Blink a LED a few times at the beginning of the program to make sure. And if you can, try with a X-tal just to be sure.
    You do have the PIC's ground and the modems ground connected don't you? The modem ground should be on PIN 5 in the DB9 but you didn't mention that in your original post.
    I have no knowledge of AT commands so I can't help with that but assuming it's correct have you tried:
    SerOut Tx,t300,["ATH1"] ' Off Hook ATH1
    Also, is it possible that the modem needs a linefeed and/or carrage return at the end of the command?
    /Henrik Olsson.
    Last Post: - 8th March 2010, 20:58
  2. Serout to serial servo
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 12th August 2009, 16:46
    Last Post: - 13th December 2008, 17:11
  4. Keypad unlock (as in garage door possibly)
    By Fred in forum Code Examples
    Last Post: - 2nd April 2006, 04:26
  5. Replies: 11
    Last Post: - 13th July 2005, 19:26
