there are code example check it out
/*******************************NAMH BHAGWATE VASUDEVAY********************************
** PROGRAM FOR ATMEL 125KHZ. RFID READER
** USING CPU PHILIPS "P89C51RD2BN"
** XTL = 22.1184MHZ.
PIN CONNECTIONS ||CFE = P3.5;rfin=P3^6;stnby=p3^7;
#include <reg52.h>
#include <stdio.h>
#include <intrins.h>
#include <string.h>
// #include "Kboard.h"
// #include "lcd_rfid.h"
sbit cfe =P3^5;
sbit rfin =P3^6;
sbit standby =P3^7;
sbit led =P1^1;
#define LED_ON led=0;
unsigned int i=0,j=0;
unsigned char buffer[10],buf_count,bit_count,byte_count;
unsigned char key,c_data,status_flag,bit_flag, temp=0x01;
FUNCTION PROTOTYPES
void bit_time_delay();
void first_bit_delay();
void collect_data();
void show_data();
void main()
/* SCON = 0x50; /* SCON: mode 1, 8-bit UART, enable rcvr /
TMOD |= 0x20; /* TMOD: timer 1, mode 2, 8-bit reload /
TH1 = -6; /* TH1: reload value for 9600 baud @ 22.1184 Mhz /
TR1 = 1; /* TR1: timer 1 run /
ET0 = 1; /* Enable Timer 0 Interrupts /
TR0 = 1; /* Start Timer 0 Running /
TI = 1; /* TI: set TI to send first char of UART /
init_lcd();
KB_init();
delay_wait(100);
rfin =1; /* radio friquency in from rfic */
standby =1; /* standby enable power of rf module */
i=0,j=0;
buf_count=0;
bit_count=0;
byte_count=0;
cfe=1;
// backlit_on;
/*-----------------------------test debug aria---------------------------*/
// first_bit_delay();
// bit_time_delay();
while(1)
i=0,j=0;
buf_count=0;
bit_count='0';
byte_count=0;
key=0x00;
bit_count=0;status_flag=1; // sequence flag=1
while(rfin); // wait to start transi.
backlit_on;
first_bit_delay(); //384 delay
while(status_flag && bit_count<9)// examin frist 9 bit to high
if(rfin==0){status_flag=0;}
bit_time_delay();
bit_count++;
if(status_flag==0)
{lcd_puts("error");delay_wait(1000);}
if(status_flag)
while(byte_count<=10) // collecting data
temp=0x01;
for(bit_count=0;bit_count<=5;bit_count++)
if(rfin){c_data |=temp; }// 0x01 // 0000 0001 lsb frist
temp<<= 1;
bit_time_delay();
c_data &= 0x1f;
buffer[buf_count]=c_data;
c_data=0;
buf_count++;
byte_count++;
} //-------------------------collecting data
buf_count=0;
send_command(0x80);
while(buf_count<=10)
key=buffer[buf_count];
key &= 0x0f;
key= key+0x30;
lcd_putc(key); //printf("%c ",key);
buf_count++;
delay_wait(2000);
lcd_clear();
backlit=1; // cfe=1;
while((key=getkey())!='#');
} // while1
}// main */
/*&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&& END OF MAIN &&&&&&&&&&&&&&&&&&&&&&&&&&&/
void bit_time_delay() // delay = 512
for(j=0;j<116;j++);
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
void first_bit_delay() // delay= 384
for(i=0;i<87;i++);
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
hello dear if not works care on delay routine and bit collection (>>)
