U2270 RFID transponder
Results 1 to 2 of 2
    Italy
    Default U2270 RFID transponder
    Hello,
    Does anybody have code example for reading the data stream of a U2270B transponder ?
    I see that they are 64 bit, manchester encoded, but I don't know how to write a simple code (interrupt driven or not) that trigger the first 9 sync bit and capture the remaining data bits.
    Please help ...
    ajay4u1976's Avatar
    ajay4u1976 Guest
    Thumbs up from a to z solution (ajay4u)
    Quote Originally Posted by Marcick View Post
    Hello,
    Please help ...
    there are code example check it out
    /*******************************NAMH BHAGWATE VASUDEVAY********************************
    ** PROGRAM FOR ATMEL 125KHZ. RFID READER
    ** USING CPU PHILIPS "P89C51RD2BN"
    ** XTL = 22.1184MHZ.
    PIN CONNECTIONS ||CFE = P3.5;rfin=P3^6;stnby=p3^7;
    #include <reg52.h>
    #include <stdio.h>
    #include <intrins.h>
    #include <string.h>
    // #include "Kboard.h"
    // #include "lcd_rfid.h"
    sbit cfe =P3^5;
    sbit rfin =P3^6;
    sbit standby =P3^7;
    sbit led =P1^1;
    #define LED_ON led=0;
    unsigned int i=0,j=0;
    unsigned char buffer[10],buf_count,bit_count,byte_count;
    unsigned char key,c_data,status_flag,bit_flag, temp=0x01;
    FUNCTION PROTOTYPES
    void bit_time_delay();
    void first_bit_delay();
    void collect_data();
    void show_data();
    void main()
    /* SCON = 0x50; /* SCON: mode 1, 8-bit UART, enable rcvr /
    TMOD |= 0x20; /* TMOD: timer 1, mode 2, 8-bit reload /
    TH1 = -6; /* TH1: reload value for 9600 baud @ 22.1184 Mhz /
    TR1 = 1; /* TR1: timer 1 run /
    ET0 = 1; /* Enable Timer 0 Interrupts /
    TR0 = 1; /* Start Timer 0 Running /
    TI = 1; /* TI: set TI to send first char of UART /
    init_lcd();
    KB_init();
    delay_wait(100);
    rfin =1; /* radio friquency in from rfic */
    standby =1; /* standby enable power of rf module */
    i=0,j=0;
    buf_count=0;
    bit_count=0;
    byte_count=0;
    cfe=1;
    // backlit_on;
    /*-----------------------------test debug aria---------------------------*/
    // first_bit_delay();
    // bit_time_delay();
    while(1)
    i=0,j=0;
    buf_count=0;
    bit_count='0';
    byte_count=0;
    key=0x00;
    bit_count=0;status_flag=1; // sequence flag=1
    while(rfin); // wait to start transi.
    backlit_on;
    first_bit_delay(); //384 delay
    while(status_flag && bit_count<9)// examin frist 9 bit to high
    if(rfin==0){status_flag=0;}
    bit_time_delay();
    bit_count++;
    if(status_flag==0)
    {lcd_puts("error");delay_wait(1000);}
    if(status_flag)
    while(byte_count<=10) // collecting data
    temp=0x01;
    for(bit_count=0;bit_count<=5;bit_count++)
    if(rfin){c_data |=temp; }// 0x01 // 0000 0001 lsb frist
    temp<<= 1;
    bit_time_delay();
    c_data &= 0x1f;
    buffer[buf_count]=c_data;
    c_data=0;
    buf_count++;
    byte_count++;
    } //-------------------------collecting data
    buf_count=0;
    send_command(0x80);
    while(buf_count<=10)
    key=buffer[buf_count];
    key &= 0x0f;
    key= key+0x30;
    lcd_putc(key); //printf("%c ",key);
    buf_count++;
    delay_wait(2000);
    lcd_clear();
    backlit=1; // cfe=1;
    while((key=getkey())!='#');
    } // while1
    }// main */
    /*&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&& END OF MAIN &&&&&&&&&&&&&&&&&&&&&&&&&&&/
    void bit_time_delay() // delay = 512
    for(j=0;j<116;j++);
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    void first_bit_delay() // delay= 384
    for(i=0;i<87;i++);
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    hello dear if not works care on delay routine and bit collection (>>)
  1. Parallax RFID Reader code example
    By dan-tron in forum Code Examples
    Last Post: - 19th April 2013, 23:16
  2. Garbage in from RFID
    By lilimike in forum Serial
    Last Post: - 6th December 2009, 15:55
  3. Replies: 3
    Last Post: - 12th March 2008, 06:33
  4. Free Web based RFID Online Courses
    By Thirumoorthy in forum General
    Last Post: - 19th November 2007, 14:38
  5. Free web based RFID online Course
    By Lesikar in forum GPS
    Last Post: - 19th October 2007, 23:28
