you have thishow about this?WHILE PORTA.1 = 0 PAUSE 1 'WHY DOES THIS NOT WORK?
WEND
WHILE PORTA.1 = 0
PAUSE 1 ' moved to its own line
WEND
WEND
WHILE PORTA.1 = 0
WEND
Paul Borgmeier
Salt Lake City, UT
USA
__________________
and you do not appear to have a "DISABLE" before your INT routine, but you do have an "ENABLE" after it.
Paul Borgmeier
Salt Lake City, UT
USA
__________________
Hi,WHILE PORTA.1 = 0 PAUSE 1 'WHY DOES THIS NOT WORK?
WEND
You can also use a : to use multiple statements on the same line.
Thus your code should be
Code:WHILE PORTA.1 = 0 :PAUSE 1 'THIS WORKs !!! WEND
Sougata
Thanks. I am so used to GWBASIC that I expected PICBASIC to be the same.
I don't know why I need an ENABLE or DISABLE, can't I just eliminate both?
Russ
Darrel has made working with interrupts so much easier with his Instant Interrupts. You might try this method.
Wisdom is knowing what path to take next... Integrity is taking it.
Ryan Miller
Thanks Ryan, I downloaded the files and it looks interesting but I don't have a clue what to do with them. Right now I need an interrupt and am looking for an easy fix. This is my program, it is a sequencer and the sequence works ok as long as the interrupt routine is not there. When the interrupt routine is there (ON INTERRUPT commented out), all the portb outputs are stuck low.
REM PORT B ARE OUTPUT, INTERCEPT ON PORTA.1
CMCON = %00001101 'COMPARATOR 2 USED, C1 DISABLED
VRCON = %11101100 'VREF ENABLED, OUTPUT ON RA2(PIN1), V = 2.5V
TRISA = %00000010 'PORTA.1 IS STOP INPUT
TRISB = %00000000 'ALL OUTPUTS
'ON INTERRUPT GOTO STOPSUB
STOPSUB:
WHILE PORTA.1 = 0 : STOP : WEND
RESUME
REM SET OUTPUTS HIGH INITIALLY
HIGH PORTB.0 : HIGH PORTB.1 : HIGH PORTB.2 : HIGH PORTB.3
HIGH PORTB.4 : HIGH PORTB.5 : HIGH PORTB.6 : HIGH PORTB.7
START:
LOW PORTB.0 : PAUSE 5000 : HIGH PORTB.0
LOW PORTB.1 : PAUSE 5000 : HIGH PORTB.1
LOW PORTB.2 : PAUSE 5000 : HIGH PORTB.2
LOW PORTB.3 : PAUSE 5000 : HIGH PORTB.3
LOW PORTB.4 : PAUSE 5000 : HIGH PORTB.4
LOW PORTB.5 : PAUSE 5000 : HIGH PORTB.5
LOW PORTB.6 : PAUSE 5000 : HIGH PORTB.6
LOW PORTB.7 : PAUSE 5000 : HIGH PORTB.7
GOTO START
Hey Russ -
Either I'm blind, or you don't have any interrupts enabled. Read through the threads on Darrel's instant interrupt routines. It's well documented, and there are plenty of examples. If I'm blind.... please point out where you are INTCON register. To be honest... I haven't played around with them much, but I'll try to help if I can.
Ryan Miller
