External clock
Results 1 to 2 of 2
Thread: External clock
    Jan 2007
    Default External clock
    It is my first time using an external oscillator. I am using an 18F4525. I have connected a ABRACON Half Size TTL/HCMOS Clock Oscillator PN/ACH-40-EK to the OSC1 pin (40.0 mHz). The oscillator outputs a saw tooth wave form from 1.8 volts to 3.1 volts.
    The clock speed of the 18F4525 appears to be about 400 times too slow. Nothing I do changes to speed. I am also unable to get the Fosc/4 signal out of OSC2 when I configure OSC = EC.
    The LED changes state approx every four seconds if I use the code:
    DEFINE OSC 40
    TRISA.1 = 0
    ch1 var PORTA.1
    loop:
    HIGH ch1
    PAUSE 100
    LOW ch1
    GOTO loop
    I have edited my 18F4525.inc file located in my c:\pbp directory to the following:
    NOLIST
    ifdef PM_USED
    LIST
    "Error: PM does not support this device. Use MPASM."
    NOLIST
    LIST
    LIST p = 18F4525, r = dec, w = -311, f = inhx32
    INCLUDE "P18F4525.INC" ; MPASM Header
    CONFIG OSC = ECIO6 ; Ext Clock with I/O on RA6
    CONFIG IESO = OFF ; Disable Internal External Osc. Switch Over
    CONFIG PWRT = OFF ; Disable Power-up Timer:
    CONFIG BOREN = OFF ; Disable brownout reset
    CONFIG WDT = OFF ; Disable watch dog timer
    CONFIG MCLRE = OFF ; MCLR pin disabled; RE3 input pin enabled
    CONFIG PBADEN = OFF ;Port B A/D disabled
    CONFIG LVP = OFF ;Low voltage ISCP disabled
    CONFIG FCMEN = OFF ; Fail-Safe Clock Monitor disabled
    NOLIST
    LIST
    EEPROM_START EQU 0F00000h
    BLOCK_SIZE EQU 8
    I have also tried:
    OSCCON.0 = 0
    OSCCON.1 = 0
    Do I have the wrong part?
    Is my configuration wrong?
    Does the wave form from the oscillator need to cross zero?
    Jan 2007
    Got it working, it appears there was something wrong with the oscillator. The bottom of the wave is now < 1 volt.
    Nevermind.
  1. Data Out From External Clock
    By Quin in forum Serial
    Last Post: - 25th October 2008, 10:11
  2. 16F887 20Mhz External Clock Problems
    By modifyit in forum mel PIC BASIC Pro
    Last Post: - 3rd September 2008, 14:11
  3. external clock / internal clock
    By grounded in forum General
    Last Post: - 31st May 2008, 18:44
  4. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 21:36
  5. How to set external clock source in PBP
    By TurboLS in forum mel PIC BASIC Pro
    Last Post: - 19th February 2005, 16:56
