Writing to an SD Card/PIC18F2480
Results 1 to 7 of 7
    Mar 2005
    Iowa, USA
    Default SD info
    THIS site seems to have some good information to get you started. They also have FAT16 code you can purchase at a reasonable price.... Although, since this is for a school project I'd strongly discourage you from buying a solution. There's some good information at the bottom of the page.
    Wisdom is knowing what path to take next... Integrity is taking it.
    Ryan Miller
    Mentor, Ohio
    Smile
    Hello,
    Here is another site that sells an SD recorder that takes input from RS232 devices. www.roguerobotics.com/products/electronics/ummc. Seems reasonably priced. But like the earlier replies, this will be a complicated project if you haven't done anything like this before.
    HTH,
    BobK
    Mar 2005
    Iowa, USA
    HERE'S a hardware solution I've been wanting to try.
    Ryan Miller
    Hi-
    There is a 2 part article on the use of multimedia cards in the Nov and Dec issues of everyday Practical Electronics (www.epemag.com). You can buy the back issues as PDF files. They even have demo files.
    Hope you come right with your project
    regards
    Angus Anderson
  1. SD Card file attributes with SDFS3 ?
    By Chris Barron in forum mel PIC BASIC Pro
    Last Post: - 27th March 2009, 10:18
  2. Writing to SD card
    By dhouston in forum mel PIC BASIC Pro
    Last Post: - 9th November 2007, 12:23
  3. Sd interface board
    By T_J_W in forum mel PIC BASIC Pro
    Last Post: - 15th August 2007, 13:00
  4. Problem on writing EEPROM in Winpic800 with picbasic pro
    By selimkara in forum mel PIC BASIC Pro
    Last Post: - 4th May 2007, 17:33
  5. pic + alfat sd
    By ranaz in forum General
    Last Post: - 27th July 2006, 07:08
