RANDOM - always the same result
Results 1 to 9 of 9
    SWITZERLAND (french speaking)
    Default Ben...
    j'ai l'air un peu c.. avec ma "graine"
    a) So, when the statement is RANDOM RandomVar, the "output" value will be stored in RandomVar, no?
    b) R_V0 = rvalue & $03 will keep only the 4 LSB of the result, no?
    c) still don't understand why my code in post#1 doesn't work. Must I specify it is in a loop? It is and doesn't work.
    Roger
    LMAO you don't want to know the meaning of the Quebec expression 'Graine'
    Indeed
    Nope, 3=%00000011 so only the 2 LSBs
    I guess you should use something like
    rvalue=R_V0 before using Random again...
    Default well...
    I have some kind of idea...
    I'm coming over to CANADA next winter for holidays. Let me know which words, I European, shouldn't use
    I thought the "&" operator would keep (isolate) only bits 0-3 of "Value" but I was wrong. For the fours LSB, I should have written $0F.
    What is then this "& $03" for?
    As you suggested, I modified my code as (I've added the "Value = R_V0" in le loop):
    Value Var WORD
    Store_MEM:
    FOR Counter = 0 to 20
       RANDOM Value
       R_V0 = (value & $03)
       IF Mem_L > 3 THEN READ Mem_L - 3, R_V1 'Do not allow more than 3 same # in a row
       IF R_V1 = R_V0 THEN STORE_MEM
       WRITE Mem_L, R_V0
       Mem_L = Mem_L + 1
       Value = R_V0
    NEXT
    Nevertheless, I always get the same number sequence over again.
    Roger
    Default "RANDOM" = same sequence over and over!
    Is this really RANDOM?
    I've been checking the sequence over and over again with 50 "random" generated numbers in a row.
    The result is an exact same complete sequence everytime I power-up my PIC.
    Anyone any clue?
    Roger
    Default PARALLAX - Basic Stamp explains clearly
    As often, I can find interresting information in the Basic Stamp's documentation.
    At least, at my level of comprehension, it is much more clear than the PBP Compiler's manual.
    Is someone else has (or had) the same problem as me, here is an extract of PARALLAX's BS2 documentation:
    RANDOM generates pseudo-random numbers ranging from 0 to 65535.
    They’re called “pseudo-random” because they appear random, but are
    generated by a logic operation that uses the initial value in Variable to "tap"
    into a sequence of 65535 essentially random numbers. If the same initial
    value, called the "seed", is always used, then the same sequence of
    numbers is generated
    In applications requiring more apparent randomness, it's necessary to
    "seed" RANDOM with a more random value every time. For instance, in
    the demo program below, RANDOM is executed continuously (using the
    previous resulting number as the next seed value) while the program
    waits for the user to press a button. Since the user can’t control the timing
    of button presses very accurately, the results approach true randomness.
    FOR trials = 1 TO 100 ' flip coin 100 times
    Hold:
    RANDOM flip ' randomize while waiting
    BUTTON Btin, 0, 250, 100, btnWrk, 0, Hold ' wait for button press
    IF (coin = 0) THEN ' 0 = heads, 1 = tails
    DEBUG CR, "Heads!"
    heads = heads + 1 ' increment heads counter
    DEBUG CR, "Tails..."
    tails = tails + 1 ' increment tails counter
    NEXT
    PARALLAX "BASIC Stamp Syntax and Reference Manual Version 2.1
    NB: Forum Administrators - please let me know if reproducing this kind of information is not allowed.
    Roger
  1. Strugling without floating point
    By pjsmith in forum mel PIC BASIC Pro
    Last Post: - 27th March 2011, 06:29
  2. Random Numbers
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 18th December 2008, 08:47
  3. 6 random numbers limiting to 49 ?????
    Last Post: - 15th June 2005, 23:27
  4. Random number results
    By bartman in forum mel PIC BASIC
    Last Post: - 9th March 2005, 17:39
  5. Random function - How to limit it ??
    By martarse in forum mel PIC BASIC Pro
    Last Post: - 30th November 2004, 14:05
