RANDOM - always the same result
Results 1 to 9 of 9
    SWITZERLAND (french speaking)
    Default RANDOM - always the same result
    Hello,
    I'm doing something so obviously wrong, I can't see the tree in the forest anymore.
    rvalue VAR WORD
    random rvalue
    R_V0 = (RValue//4) + 1 ' Convert it to range 1-4
    if R_V0 = 1 then high led1
    if R_V0 = 2 then high led2
    if R_V0 = 3 then high led3
    if R_V0 = 4 then high led4
    The code above will always show "led3".
    What's wrong here?
    Roger
    Post
    Hi,Flotul
    1) Read carefully the manual : there must be a SEED for the random function ... if always the same ... always the same result !!!
    2) a little SEARCH would be THE THING to do ... good surprise for you !!!
    Default Got it working... but I don't know why
    Bonjour Alain,
    Thanks...
    I just found a way to make it work.
    I changed my code and put R_V0 = rvalue & $03. But, to be honest, I don't understand why it works now.
    Before opening this thread, I read lots of other threads about this subject. I've also been reading the Compiler's manual. I read this "Var is used both as the seed and to store the result" but my english is to poor and I don't understand the correct meaning of the word "seed" (graine - in french) here.
    Could you explain this command in other words please?
    Roger
    Kind of 'conjugaison du verbe voir => see, seed'.
    Qu'est-ce qui a déja été vue, sortie, choisi, sélectionné.
    Default Ben...
    j'ai l'air un peu c.. avec ma "graine"
    a) So, when the statement is RANDOM RandomVar, the "output" value will be stored in RandomVar, no?
    b) R_V0 = rvalue & $03 will keep only the 4 LSB of the result, no?
    c) still don't understand why my code in post#1 doesn't work. Must I specify it is in a loop? It is and doesn't work.
    Roger
    LMAO you don't want to know the meaning of the Quebec expression 'Graine'
    Indeed
    Nope, 3=%00000011 so only the 2 LSBs
    I guess you should use something like
    rvalue=R_V0 before using Random again...
    Default well...
    I have some kind of idea...
    I'm coming over to CANADA next winter for holidays. Let me know which words, I European, shouldn't use
    I thought the "&" operator would keep (isolate) only bits 0-3 of "Value" but I was wrong. For the fours LSB, I should have written $0F.
    What is then this "& $03" for?
    As you suggested, I modified my code as (I've added the "Value = R_V0" in le loop):
    Value Var WORD
    Store_MEM:
    FOR Counter = 0 to 20
       RANDOM Value
       R_V0 = (value & $03)
       IF Mem_L > 3 THEN READ Mem_L - 3, R_V1 'Do not allow more than 3 same # in a row
       IF R_V1 = R_V0 THEN STORE_MEM
       WRITE Mem_L, R_V0
       Mem_L = Mem_L + 1
       Value = R_V0
    NEXT
    Nevertheless, I always get the same number sequence over again.
    Roger
    Default "RANDOM" = same sequence over and over!
    Is this really RANDOM?
    I've been checking the sequence over and over again with 50 "random" generated numbers in a row.
    The result is an exact same complete sequence everytime I power-up my PIC.
    Anyone any clue?
    Roger
    Default PARALLAX - Basic Stamp explains clearly
    As often, I can find interresting information in the Basic Stamp's documentation.
    At least, at my level of comprehension, it is much more clear than the PBP Compiler's manual.
    Is someone else has (or had) the same problem as me, here is an extract of PARALLAX's BS2 documentation:
    RANDOM generates pseudo-random numbers ranging from 0 to 65535.
    They’re called “pseudo-random” because they appear random, but are
    generated by a logic operation that uses the initial value in Variable to "tap"
    into a sequence of 65535 essentially random numbers. If the same initial
    value, called the "seed", is always used, then the same sequence of
    numbers is generated
    In applications requiring more apparent randomness, it's necessary to
    "seed" RANDOM with a more random value every time. For instance, in
    the demo program below, RANDOM is executed continuously (using the
    previous resulting number as the next seed value) while the program
    waits for the user to press a button. Since the user can’t control the timing
    of button presses very accurately, the results approach true randomness.
    FOR trials = 1 TO 100 ' flip coin 100 times
    Hold:
    RANDOM flip ' randomize while waiting
    BUTTON Btin, 0, 250, 100, btnWrk, 0, Hold ' wait for button press
    IF (coin = 0) THEN ' 0 = heads, 1 = tails
    DEBUG CR, "Heads!"
    heads = heads + 1 ' increment heads counter
    DEBUG CR, "Tails..."
    tails = tails + 1 ' increment tails counter
    NEXT
    PARALLAX "BASIC Stamp Syntax and Reference Manual Version 2.1
    NB: Forum Administrators - please let me know if reproducing this kind of information is not allowed.
    Roger
  1. Strugling without floating point
    By pjsmith in forum mel PIC BASIC Pro
    Last Post: - 27th March 2011, 07:29
  2. Random Numbers
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 18th December 2008, 09:47
  3. 6 random numbers limiting to 49 ?????
    Last Post: - 16th June 2005, 00:27
  4. Random number results
    By bartman in forum mel PIC BASIC
    Last Post: - 9th March 2005, 18:39
  5. Random function - How to limit it ??
    By martarse in forum mel PIC BASIC Pro
    Last Post: - 30th November 2004, 15:05
