Peek Poke pic16f870
Results 1 to 5 of 5
    Jul 2006
    Cool updated code
    I have made some changes to my code and am understanding why it was doing what it was doing. I am trying to use the examples from the PICBASIC compiler hand book page 47 to write my code. I am trying to use the first four pins on PortA and PortC to control two motors through an H bridge using port B pins 4,5 for motor 1 and 6,7 for motor 2. The example code says:
    Loop: Peek PortA,B0 'get current portA pin states to variable B0
    If bit0=1 then zerohigh
    If bit1=0 then onelow
    goto loop
    zerohigh: high 0
    gotoloop
    onelow: low 1
    goto loop
    So this is why in my code I was using bits. According to the Pg 20 of this manual that came with my basic compilier it says that the first tow bytes , B0 and B1 may also be used as bit variables. Bit0...Bit7 for B0 and bit8...bit15 for B1. So this is why I had the use of bit8 in my orginal code. But may be there is a better way to do this and if so I would like to know. Here is my revised code.
    symbol cmcon=$1f
    poke cmcon,7
    symbol adcon0=$9f
    poke adcon0,7
    symbol adcon1=$9f
    poke adcon1,7
    start:
    peek 5, B0
    if bit0=0 then A
    if bit0=1 then D
    peek 7, B1
    if bit8=0 then B
    if bit8=1 then C
    goto start
    A: low 6: high 7: Return
    B: low 4: high 5: Return
    C: low 7: Return
    D: low 5 Return
    Please tell me how I can fix my code It still seems like peek and poke arent working right for me.
    Thanks for you Help.
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Eric,
    This will get you closer - I maintained your logic exactly, which, looks to me, to be a bit troubling as SKIMASK noted. You also will want to get a copy of the 16F870 datasheet to go with the manual. Email back if you want more.
    ;symbol cmcon=$1f	; 16F870 has no comparators and $1f is ADCON0 not CMCON
    ;poke cmcon,7	; this line and above not needed for the 18F870
    ;symbol adcon0=$9f  ; $9F is ADCON1 not ADCON0 – these two lines repeat the next two
    ;poke adcon0,7
    symbol adcon1=$9f
    poke adcon1,7	; Make all of PORTA Digital rather than analog
    Poke, $85, %00000011	; make pins 0 and 1 on PORTA inputs, the rest outputs
    Poke, $87, %00000011	; make pins 0 and 1 on PORTC inputs, the rest outputs
    Poke $86, %00000000    	  ; make all of PORTB outputs
    Poke $05, 0			; make all outputs of PORTA low
    Poke $06, 0			; make all outputs of PORTB low
    Poke $07, 0			; make all outputs of PORTC low
    start:
    peek 5, B0			; read PORTA into predefined variable B0
    if bit0=0 then A		; if B0.0 = 0 then GOTO A (no gosub in if statement)
    ReturnFromA:
    if bit0=1 then D		; if B0.1 = 1 then GOTO D (no gosub in if statement)
    ReturnFromD:
    peek 7, B1			;  Read PORTC into B1
    if bit8=0 then B		; if B1.0 = 0 then GOTO B
    ReturnFromB:
    if bit8=1 then C		; if B1.0 = 1 then GOTO C
    goto start
    A: low 6: high 7	; make PORTB pin 6 low and pin 7 high
    Goto ReturnFromA
    B: low 4: high 5	; make PORTB pin 4 low and pin 5 high
    ReturnFromB
    C: low 7		; make PORTB pin 7 low
    Goto Start
    D: low 5  		; make PORTB pin 5 high
    Goto ReturnFromD
    oh, I have not tried this - I do not use PBC anymore ... and you might want to start your project by trying to blink and LED or two rather than trying to code a complete program.
    Last edited by paul borgmeier; - 16th March 2007 at 08:03. Reason: fix spelling (it's late)
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
  1. Could I please ask for some help on my code
    By opticaltrigger in forum mel PIC BASIC
    Last Post: - 25th January 2010, 00:45
  2. Can't get ADC to loop
    By TravisM in forum mel PIC BASIC
    Last Post: - 11th October 2009, 16:33
  3. Code entering endless loop
    By Blackhawk in forum mel PIC BASIC
    Last Post: - 26th November 2006, 10:12
  4. First Day and need Help!
    By timmoore47 in forum mel PIC BASIC
    Last Post: - 3rd June 2006, 23:13
  5. Output PIC module
    By freelancebee in forum mel PIC BASIC Pro
    Last Post: - 12th September 2005, 21:10
