Please, help me?
Results 1 to 6 of 6
Threaded View
  1. #2
    Feb 2005
    Kolkata-India
    Default Hello Onix
    What sort of help do you exactly need ? Like schematic design, Code examples in PBP or ASM. Please clarify. This forum is a nice place and you will definately find it useful. You can start writing your program in PBP to test out your circuit. If you have to use ASM only then this is the right time you should start learning it.
    Best of Luck.
    P.S. I looked up your other post and understood that you require PBP sample codes. Please post your schematic and your asm code already with you.
    Last edited by sougata; - 15th March 2007 at 12:01. Reason: Found the other thread started late!
    Sougata
