Bad Eeprom write on '628???
Results 1 to 12 of 12
    Bombay, India
    You should not write to the EEPROM every second. The number of writes is limited if you know. Ideally, if you need to save, you should save only if there is a change in status of the port. This will reduce the number of writes.
    This looks like a test program to me. So, please think of your real application. You may not need to update the EEPROM so frequently..
    Jerson
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    1)You haven't declared last_val
    2)If you lose power while writing to the EEPROM your saved value might be corrupt
    3)You most likely will shut off power during the pause 1000 – in this case you would not expect to see the same number when you repower up. Say you had PORTB = 28 when the power went down (during the Pause 1000). 28 should be in the EEPROM. When you reapply power, the number 28 is read back and put on PORTB. a few microseconds later you add 1 to that and display the new value, which you see. Therefore 28 !=29.
    4)Jerson is right – your eeprom is limited in the number of writes – how about detecting the power loss and writing the value to EEPROM before the power drops out?
    5)
    Ovbiously I init the eeprom data with a number before taht the pic can run on first time!
    Not to me, I don't see it in your code.
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Jul 2006
    Default but . . .
    Thanks by your comments friends, my real app is simple y try to make a ir (infrared) control box that control 4 relays the only that i need is save the last relays status when a possible reset ocurr!, it ensure that there is no change when the power suply is shut down!
    last_val is a byte sized var, and I do not write a statemment as
    " WRITE 0,1" ;INIT EEPROM
    instead I mod the eeprom data memory in MPlab when i burn the Chips, so
    How I can detect a power loss?, what is then the best way to do this type of things?
    my idea is save the PORTB status ONLY when a new value is reloaded from a an Ir controller, instead each second as the above code is!.
    Thanks Again!
    Feb 2003
    Smile
    Lot of ways to do this ... without a schematic or more detail it is hard to say what is best. For moderately low power projects, I place a fast diode between the power supply and VDD. I also place a cap between VDD and GND. I then monitor the voltage from the anode of the diode (also connected to the PIC through a diode) and sense when it goes low (with ADC or Comparators). When it goes low, I shut off everything and write to EEPROM. I size the cap to give me enough time to do this.
    Others might do this differently (like using BOD).
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Jul 2006
    Default This is my circuit
    As you can see the schematic is very simple.
    I try to make the changes what you say, view the ADDED.jpg file I think that this may work, today I also make code changes and i try again, let know if the the squematics looks like you say,
    Feb 2003
    I have given this consideration for a project that I am working on as well.
    Realistically how often is the status of the relays going to change ?
    How many times per day in total ?
    The EEPROM typically has a life of 1 million cycles which can be used up very quickly with frequent updates, or may well outlive everyone on this list if the frequency of updates is quite low.
    What is the designed lifespan for your product ?
    1 second = 86400 per day = 11.57 days
    10 seconds = 8640 per day = 115.7 days
    30 seconds = 2880 per day = 347 days
    1 minute = 1440 per day = 694 days
    5 minutes = 288 per day = 9.5 years
    10 minutes = 144 per day = 19.0 years
    30 minutes = 48 per day = 57.1 years
    1 hour = 24 per day = 114 years
    2 hours = 12 per day = 228 years
    6 hours = 4 per day = 685 years
    12 hours = 2 per day = 1370 years
    24 hours = 1 per day = 2740 years
    If there are less than 50 updates per day then I wouldnt bother trying to detect power failure as its going to take over 50 years to kil the eeprom, even updating every five minutes will give you the best part of 10 years.
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Mentor, Ohio
    Smile
    Hi Keith,
    Something has been bugging me for several years after reading about the lifetime of an EEPROM. Is the lifetime determined by how many times you write to the EEPROM as a whole or is it per location of the EEPROM? Just curious.
    BobK
    Bombay, India
    Thumbs up
    Quote Originally Posted by keithdoxey View Post
    Keith
    This post of yours is brilliant. You explain very clearly the way the million cycles can be used up and how fast.
    Jerson
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 14:46
  2. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 03:17
  3. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 14:19
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 19:59
