How to configure SPI in PICBASIC PRO?
Results 1 to 14 of 14
    Mar 2007
    Default How to configure SPI in PICBASIC PRO?
    I tried to configure two PIC16F877As as SPI master and SPI slave. Pls refer to schematic shown in figures in attachment. Master will send a '?' to acknowledge the slave. Then, the slave will reply with a '!'. Once master receives '!', it will start to receive data from slave, which is a '5' character. The charater will then be displayed on the LCD.
    The SPI communication between the master/slave did not work. Pin B0 of master is connected to A5/SS of slave. Pls advise if you find mistakes in the schematic as well as the source code.
    For your information, I'm using PicBasic Pro 2.47 compiler.
    Source Code (MASTER)
    ' PicBasic program to demonstrate operation of an LCD in 4-bit mode
    ' LCD should be connected as follows:
    '       LCD     PIC
    '       DB4     PortD.4
    '       DB5     PortD.5
    '       DB6     PortD.6
    '       DB7     PortD.7
    '       RS      PortD.2
    '       E       PortD.3
    '       RW      Ground
    '       Vdd     5 volts
    '       Vss     Ground
    '       Vo      10K potentiometer (or ground)
    ' PicBasic Pro program to read and write to SPI slave
    ' using the synchronous serial port
    ' Connect SDI(master) to SDO(slave), SDO(master) to
    ' SDI(slave), AND SCK(master) to SCK(slave).
    ' Common Ground is required.
    ' Sends ascii "?" to request data, waits for a "!" to
    ' begin receiving data. Expect to receive "5" (without quotes)
    ' from slave and display it LCD.
    DEFINE LCD_LINES 4 'number of LCD lines
    DEFINE LCD_DREG PORTD
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTD
    DEFINE LCD_EBIT 3
    DEFINE LCD_BITS 4
    DEFINE LCD_RSBIT 2
    DEFINE LCD_EREG PORTD
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 40
    SSPEN  VAR  SSPCON.5 'SSP Enable bit
    CKP  VAR  SSPCON.4 'Clock Polarity Select
    SMP  VAR  SSPSTAT.7 'Data input sample phase
    CKE  VAR  SSPSTAT.6 'Clock Edge Select bit
    SSPIF  VAR  PIR1.3  'SPI interrupt flag
    a  VAR  BYTE
    TRISC = 0   'set PORTC I/O
    TRISB = %11111110  'set PORTB.0 as output
    SSPEN = 1   'enable SPI pins
    CKP = 0    'clock idle low
    CKE = 0    'transmit on idle to active transition
    SSPIF = 0   'clear buffer full status
    SMP = 0    'sample in middle of data
    LOW PORTB.0
    loop:
    GoSub getdata   'initiate conversion and receive data
    LCDOut $fe, 1,
    LCDOut #a
    Pause 1000
    GoTo loop   'do it forever
    getdata:
    HIGH PORTB.0   'enable ss pin
    SSPBUF = "?"   'send ? to start conversion
    GoSub letclear   'wait for buffer to clear
    IF SSPBUF<>"!" Then getdata 'wait for reply (!)
    SSPBUF = 0   'write to SSPBUF to start clock
    GoSub letclear   'wait for receipt
    a = SSPBUF   'store received character in array
    LOW PORTB.0
    letclear:
    IF SSPIF = 0 Then letclear 'wait for SPI interupt flag
    PauseUs 25   '25uS fudge factor
    SSPIF = 0   'reset flag
    Source Code (SLAVE)
    ' PicBasic Pro SPI slave program (see SPImast.bas for connections)
    dataout  VAR      WORD
    SSPIF  VAR  PIR1.3  'interrupt flag - last bit set
    TRISC = %11011111  'set PORTC I/O
    TRISA = %11011111  'set PORTA.5 as input.
    SSPCON = %00000100  'configure SPI slave, enable SS pin
    SSPIF = 0   'clear SPI interrupt
    dataout[0] = "5"
    loop:
    SSPEN = 0   'disable/enable SSP to reset port
    SSPEN = 1
    GoSub letclear   'wait for byte received
    IF (SSPBUF <> "?") Then loop 'wait for ? to start conversion
    GoSub senddata   'send "!" and string of data
    senddata:
    GoSub letclear   'wait until buffer ready
    SSPBUF = "!"   'send reply
    SSPBUF = dataout[0]  'send variable
    letclear:
    IF SSPIF = 0 Then letclear 'wait for interrupt flag
    Jun 2005
    Penang
    Default Resistor..
    Had you tried placing pull down resistor on SS pin.There is a chance slave get "crazy" as the SS pin will sometimes float (OC).
    Mar 2007
    Quote Originally Posted by NatureTech View Post
    Yes, I have added the pull down resistor at SS pin but it still could not work.
    I have some doubts on how to write and read SSPBUF in PICBASIC PRO.
    When I execute the following code, which I assume it as 'write to SSPBUF':
    SSPBUF = "?"
    I could see a 8-pulse train at SCK of the master.
    If I'm not mistaken, communication between master/slave is initiated by SCK (clock) of the master, right? If that is the case, how do we read (in PICBASIC PRO) from the slave? Pls refer to the code below:
    Pls advise if there is any read operation above? How does the master start the clock during read operation?
    Thanks.
    Mar 2007
    Latest version of code... but still can't work... Pls advise.
    Quote Originally Posted by moogle View Post
    '       LCD     PIC
    '       DB4     PortD.4
    '       DB5     PortD.5
    '       DB6     PortD.6
    '       DB7     PortD.7
    '       RS      PortD.2
    '       E       PortD.3
    '       RW      Ground
    '       Vdd     5 volts
    '       Vss     Ground
    DEFINE LCD_DBIT 4
    DEFINE LCD_EBIT 3
    DEFINE LCD_BITS 4
    DEFINE LCD_RSBIT 2
    a  VAR  BYTE
    HIGH PORTB.0
    loop:
    LCDOut $fe, 1,
    LCDOut #a
    Pause 1000
    getdata:
    LOW PORTB.0   'enable ss pin
    HIGH PORTB.0
    letclear:
    Source Code (SLAVE)
    dataout  VAR      WORD
    dataout[0] = "5"
    loop:
    SSPEN = 1
    senddata:
    letclear:
    a good exercice would be to use a SPI device and read/write to it. Anything like a EEPROM 93C06, 93C46 etc etc. Once you have something working, you should understand better how stuff work.
    Don't give up!
    Jan 2006
    New Hampshire, USA
    The datasheet says that setting TRISA = 1 sets the port as input. I believe you have it backward.
    Mar 2007
    Quote Originally Posted by Russ Kincaid View Post
    Noted...
    Should be...
    TRISA = %11111111 'set PORTA.5 as input.
    Thanks...
    Mar 2007
    Ooopss... PORTA.5 should be set as input to enable the SS. Pls correct me if I'm wrong. Thanks.
    Jan 2007
    Hi, moogle,
    I have followed your "pilgrimage" through several forums looking for helping to make to work your SPI routines.
    I also have verified the little interest that some manufacturers put in helping their clients, for example Microchip and Crownhill, this last is incapable to put a simple example of a Masters and a Slave working in SPI communications.
    I have begun to try to start up your routines but they do not work and I do not dare to write in the forums since the answers that they gave you, have been sufficiently frustrating for my.
    Well, your routines seem enough to learn a PIC-to-PIC SPI, so, if you have them working, please, put them here in the forum or send me them by mail.
    So let me see if I've got this right:
    So Microchip doesn't have any examples? There's plenty to be found in the datasheets. And any problems with the SPI module (and there are a couple here and there) are found in the errata sheets, complete with workarounds...
    And Crownhill? Well, I don't use the Proton compiler they sell. But it seems to me that if the compiler works and it's still selling well, then it's probably a good bet that the SPI routines it comes with probably work fairly well also. And besides that, how about trying http://www.picbasic.org/forum/ or http://www.google.com . The Search functions work great and I'll bet you can find loads of good examples for code at either.
    So, even though the original poster wrote in the forums looking for help because the program didn't work, you assumed that it would actually work for you and it didn't? Imagine that...
    So what you actually want is somebody else to do all the legwork for you.
    I am correct so far?
    Jan 2007
    Angry
    Hi skimask,
    Thanks you very much!, your answer is the answer that anybody can expect from people as you!.
    First of all, you say that there are a lot of examples in the Datasheets of Microchip, yes, with many errors, enough , even, to create controversies, see the PIClist, for instance. You suggest to visit the Proton+ forum or to search in Google. These suggestions are offensives. Of course!, I have search though Google, I have visited a dozen of specialized forums and I have not found a simple (only simple!) working SPI routine for a simple PIC to PIC communication in Assembler, nor in PICBasic Pro, nor in PICBasic Plus, nor in Proton, the only thing I have found is a lot of people looking for any good suggestion and all of them received suggestions as yours, nothing. So, you are not correct!.
    Second, no, sir, no, I do not assume that anybody works for me, I assume that Internet is a good site to learn anything (I am a simple hobbyst), I assume that if moogle have posted a simple routine looking for help, probably he has not problem ( I say "probably, he has not problem...", I do not say "he is forced to...") to send or to post the same routine free of errors (their routines seem very good but I think there are not NASA's designs. Sorry, moogle, that is for skimask). Moreover, before I have decided to post my message to moogle, I have spent more than one week testing my own and other routines. So, you are not correct!.
    Finally, instead of spending your precious time saying the idiot who I am, it will been simpler to put a simple link to one of the many sites in which according with you, there is a simple SPI routine of PIC to PIC. I am correct so far?
    Quote Originally Posted by virolay View Post
    My Dear Virolay,
    IF you were a PicBasicPro fan ... ( pfffff !!!!) you should have had YOURSELF your first look HERE :
    http://www.melabs.com/resources/samples.htm
    ... I'm really not used to link pics between themselves ( LOL ) ... but straight found THIS:
    spimast routine for ... spimaster
    Spislave routine for ... spislave !!!
    Now, I can understand you're a very great man AND/OR think you really are ...
    BUT, that doesn't allow you to write stupidities about suppliers from your second post on this forum ...
    " I want this " is definitly not the good key here ... so far we don't know ANYTHING about what you had hoped to realize.
    Have a nice afternoon
    Search the posts here. If you can find less than say, 50 answers I've given out to others, I'll write your code for you, test it, and hand deliver it, straight to your workshop, program your chip, and cook dinner for you.
    No, you are not correct...so far.
    Did I call you an idiot? Nope. Anybody else see that? Nope. Did I imply that? Nope.
    Would it have been simpler for me to link you to an SPI routine? Yep. Would you have actually learned something in the end? Nope.
    In my little world, it runs right back the old 'teach a man to fish' thing.
    Now then, post some code that YOU have written (not just some cut-and-paste from somebody else). And when you can't figure out why it doesn't work or why something isn't doing what you want it to do, you'll figure out what sort of answers I (or anybody that frequents these forums) can give out.
    Wink
    Hi, Skimask
    Take it easy ...
  1. VB.net and Picbasic Pro
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 15th November 2007, 21:18
  2. Replies: 0
    Last Post: - 22nd November 2005, 14:16
  3. Question for all that use MELABS PICBASIC PRO
    By oskuro in forum Off Topic
    Last Post: - 24th March 2005, 18:15
  4. PicBasic Pro & PicBasic syntax different
    By Billyc in forum General
    Last Post: - 16th April 2004, 22:19
  5. PicBasic Pro FSK Modem
    By mikep in forum mel PIC BASIC Pro
    Last Post: - 29th October 2003, 15:21
