Sorted the problem out finally, the problem is I had a 330 ohm resistor on the supply to the receiver chip, it says to do this in the datasheet if you are intending on using it on 5V - I removed the resistor and ran it on 3V and it works a treat, I might put a couple diodes on it to drop the voltage a little in future.
Thanks for helping out
