The short answer is YES. Antenna design makes all the difference.
Longer answer.
A ¼ wave only works against a ground plane, normally a wire “hanging out” does not have a ground plane to work against.
A ½ wave monopole or ½ wave dipole does not need a ground plane. The ½ monopole will have depending on the height above ground a lower radiation angle than the dipole.
Another problem to look out for. Both the transmitter antenna and receiver antenna need to be orientated the same way for maximum range. (vertical in relation to the earth or horizontal to the earth)
Longest answer.
Start here http://www.linxtechnologies.com/documents/AN-00500.pdf
then google antenna theory and design.
If you like electronics and programing you will have a blast with electromagnetic radiation (radio)
