PIC16F690 Lookup Error
Results 1 to 11 of 11
    Feb 2005
    Kolkata-India
    Default Can we have some of that spit ?
    Please post the compilation errors you are getting.
    Sougata
    Jan 2007
    Default Compilation Errors
    here you go
    Feb 2005
    Kolkata-India
    Default Are you using any org directive
    It seems that the code is compiling past the maximum available memory. The warnings should not cause panic. Have you tried using MPASM ?
    As large files are compiled and then
    assembled, they may start to use more than the first page. As each
    page is used, PM, the assembler, will issue a message that the code is
    crossing a particular boundary. This is normal and no cause for alarm.
    PBP will make sure to take care of most of the issues for you.
    However a look at your entire code may give some insight as to why it is crossing the maximum usable prog mem or if it is just a warning.
    Sougata
    Jan 2007
    Default 16F690 Lookup Issue
    I am compiling using MPASM in Microcode Studio with PBP 2.47
    Feb 2005
    Kolkata-India
    Default Can you post your code
    I can try compile and tweak if you post your code. What happens if you remove some code (say a subroutine) to test if it compiles okay.
    Sougata
    Jan 2007
    Any additional thoughts here? MElabs told me that the tables were basically gobbling up code space and I should try moving stuff around...I tried a couple things and that was to no avail.
    Quote Originally Posted by RunningMan View Post
    Post the code...let's have a look-see...maybe some of us more experienced types might be able to show you something to save some code space or something...
  1. Using input from Switch to control a loop
    Last Post: - 2nd February 2009, 05:02
  2. Loop with two motor and 2 sensors
  3. Optimizing DIV
    Last Post: - 22nd September 2008, 04:58
  4. problem with USART
    By leemin in forum Serial
    Last Post: - 11th December 2006, 17:56
  5. 16F88 Compile error
    By Toley00 in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2005, 00:22
