Post the code you're having problems with. Hard to say without seeing that.
got most things working now except
cannot get changover from 1 to 0 on gpio.0
its going high due to the pullup but when i ground does not respond
might not be explaining this properly but can work on gpio.5
where i have a resistor to gnd and a pb to 5 volts
What Seems To Be Happening Is I Cannot Get Gpi0.0 To Change State Using The Pullup
Dont Know If Its A Electrical Issue Or Not See Sample Program Above Just Grounding Pin 7 Momentarily
But Prgram Does Not Respond Works On Gpi0.5 With A Res Pulled Low And A Pb To High
Which PIC are you actually using? Your code example above indicates a 12F675, but you asked about the 12F683?
For the 12F675 you need CMCON = 7 to disable comparators.
For the 12F683 you need CMCON0 = 7 to disable comparators.
bruce i tried both but the pic12f675 works with one of my programmers beter dont have to keep swaping out the pic so thats what i am trying now
really does not mater after i get it working
How does it work with this?
Code:@ DEVICE PIC12F675,MCLR_OFF,INTRC_OSC_NOCLKOUT,WDT_OFF,BOD_ON,PWRT_ON ANSEL = 0 CMCON = 7 OPTION_REG = 0 TRISIO = %00100011 WPU = %00000011 ' Example program from manual to blink an LED connected to gpio.4 about once ' a sec led var gpio.0 loop: if led = 1 then low 2 else high 2 endif HIGH gpio.4 ' Turn on LED connected to gpio.4 Pause 1000 ' Delay for .5 seconds LOW gpio.4 ' Turn off LED connected to gpio.4 Pause 500 ' Delay for .5 seconds Goto loop ' Go back to loop and blink LED forever End
this functions but not as expected at first pin to v+ caused change
than after short time v- caused change which is what i would expect
dont quiet understand inital operation but this is doing what i want
thanks
