pin 12f683
Results 1 to 23 of 23
Thread: pin 12f683
    Cool pin 12f683
    trying to program this 8 pin pic
    trouble defining pins in pbp
    microchip manual listpins as gp0 to gp4 this does not work
    tried just pin 1 ect this compiles but does not function on pic
    whats the correct syntax for the baby chips
    Default Comparators...
    Try this:
    ANSEL = %00000000	'Make sure Analog functions are turned OFF (should not be needed)
    CMCON = 7		'Turn OFF comparators, datasheet section 8.3
    TRISIO = 0		'All pins except GPIO3(MCLR) as output.
    Start:
      GPIO.0 = 1
      Pause 100
      GPIO.1 = 0
      Pause 100
    Goto Start
    /Henrik Olsson.
    GPIO.0, GPIO.1, etc, for I/O-pins, and TRISIO for TRIS regs. Here's a sample
    I/O-pin setup header from an old 683 test program..
    @ DEVICE PIC12F683,MCLR_OFF,INTRC_OSC_NOCLKOUT,WDT_OFF,BOD_ON, PWRT_ON
    OSCCON  = %01100000     ' Internal 4MHz osc
    ADCON0 = 0              ' A/D off
    CMCON0 = 7              ' Comparators off
    ANSEL = 0	        ' Set all digital
    WPU = 0                 ' Internal pull-ups = off
    OPTION_REG = %10000000  ' Pull-ups = off, GPIO.2 = I/O, prescaler to Timer1
    GPIO = %00000000        ' All outputs = 0 on boot
    TRISIO = %00111101      ' GPIO,0=data in, GPIO,1=IRLED out, GPIO,2,3,4,5 unused
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Smile update
    this looks great
    only my program will require mostly inputs and at least 1 output
    can you tell what changes i need
    TRISIO = %11111110 would setup GPIO.0 as an output leaving the rest setup as inputs.
    What is it you're doing?
    -Bruce
    tech at rentron.com
    Default responce
    setting up a alarm for my motorhome to sound if ignition is off and trans is not in park older coach does not have this feature also will sound alarm if turn signals are on too long
    Apr 2006
    New Hampshire USA
    Smile How many pins?
    How about (slow repetition) beep if head-lights are on and ignition off?
    We should be able to get this up to a 40 pin PIC
    -Adam-
    Sounds like a cool project. The 12F683 is a really nifty part.
    My wife thinks I'm a complete nerd, so she buys me all this odd stuff like RoboSapien robots and such. I got kind of bored with it after the first few minutes, and decided to have a go at controlling the thing from my PC with an 8-pin PIC.
    I used the 12F683 since I hadn't played with this one yet 'note the date of the code'. Here's what I came up with. It's pretty simple stuff, but still fun. I have a VB interface if anyone's interested. You can connect the PIC to your PC serial port, and control your RoboSapien robot with it by clicking buttons on-screen.
    '*  Name    : RoboSapien_IR.bas                                 *
    '*  Author  : Bruce Reynolds  11/11/2005                        *
    '*  Notes   : Serial IR controller for RoboSapien robot         *
    '*          : Replace RoboSapien hand-held IR transmitter with  *
    '*          : an 8-pin PIC & IR LED. Just goofin off one day.   *
    ' Connections for a 12F683
    ' Pin #8 = gnd
    ' Pin #1 = Vcc
    ' GPIO.0 serial input from other controller or PC
    ' GPIO.1 IR LED drive ----/\/\/\---|>|----gnd  (note: use a 940nm IRLED)
    '                          330    IR LED
    ' Need more range use a simple NPN or mosfet driver.
    ' Rest of I/O-pins available for whatever.
    @ DEVICE PIC12F683, MCLR_OFF, INTRC_OSC_NOCLKOUT, WDT_OFF, BOD_ON, PWRT_ON
    DEFINE DEBUG_BAUD 2400
    DEFINE DEBUGIN_REG GPIO
    DEFINE DEBUGIN_BIT 0
    DEFINE DEBUGIN_MODE 0   ' 0 = true mode (with a PC use a MAX232)
    @ #DEFINE IRTX GPIO  ; Define port to use for IR LED drive
    @ #DEFINE PIN 1      ; Define port pin to use for IR LED
    BotHdr   CON 255     ' Pulse timing stuff
    BotHdr2  CON 25
    Bot1     CON 3400
    Bot0     CON 800
    BotInter CON 38
    Bot      CON "B"     ' Used for synch byte
    X        VAR BYTE    ' Bit index pointer
    Cycles   var BYTE    ' Holds number of 40KHz carrier cycles
    Device   VAR BYTE    ' Holds device select byte
    KeyNum   VAR BYTE    ' Key pressed
        DEBUGIN [Device,KeyNum] ' With MCS+ serial terminal program, sending B#135
        IF Device = Bot THEN    ' will move bot backwards. Full list of commands
           GOTO SendCmd         ' can be found in lower section.
        GOTO Main
    SendCmd:
        Cycles = BotHdr  ' 1st part of synch pulse
        CALL Pulse
        Cycles = BotHdr2 ' 2nd part of synch pulse
        CALL Pulse
        FOR X = 7 to 0 STEP - 1 ' 8-bits per button command
            IF KeyNum.0[X] = 1 THEN
               PAUSEUS Bot1     ' high for logic 1 bit period
               PAUSEUS Bot0     ' or low for logic 0 bit period
            Cycles = BotInter   ' Inter-bit period between data bits
            Call Pulse          ' During these periods the carier is on
        NEXT X
        GOTO Main
    Pulse:              ' Generate "Cycles" number of 40kHz pulses
       bsf IRTX,PIN     ; 1uS, LED=on
       goto $+1         ; + 2uS = 3uS
       goto $+1         ; + 2uS = 5uS
       goto $+1         ; + 2uS = 7uS
       goto $+1         ; + 2uS = 9uS
       goto $+1         ; + 2uS = 11uS
       goto $+1         ; + 2uS = 13uS
       bcf IRTX,PIN     ; 1uS, LED=off
       decfsz _Cycles,f ; + 1uS = 10S
       goto _Pulse      ; + 2uS = 12uS
       return           ; Add 2uS for return to caller
    ' Send ASCII character B followed by key commands below to
    ' control your RoboSapien from a PC or another PIC.
    ' A simple VB example to move RoboSapien forward would be;
    ' Private Sub Cmd_Forward_Click()
    ' MSComm1.Output = "B" & Chr$(134)
    ' End Sub
    ' Upper red commands
    ' Right arm up      = 129
    ' Right arm down    = 132
    ' Right arm in      = 133
    ' Right arm out     = 130
    ' Left arm up       = 137
    ' Left arm down     = 140
    ' Left arm in       = 141
    ' Left arm out      = 138
    ' Tilt body right   = 131
    ' Tilt body left    = 139
    ' Red commands - middle & lower controller
    ' Walk forward      = 134
    ' Walk backward     = 135
    ' Turn left         = 136
    ' Turn right        = 128
    ' Stop              = 142
    ' Rht sensor pgm    = 146
    ' Master command program = 144
    ' Program / play    = 145
    ' Left sensor program = 147
    ' Sonic sens pgm    = 148
    ' Green commands - upper controller
    ' Right hand thump  = 161
    ' Right hand pickup = 164
    ' Lean backward     = 165
    ' Rht hand throw    = 162
    ' Sleep             = 163
    ' Listen            = 171
    ' Left hand throw   = 170
    ' Lean forward      = 173
    ' Left hand pickup  = 172
    ' Green commands - middle & lower controller
    ' Right turn step   = 160
    ' Backward step     = 167
    ' Forward step      = 166
    ' Reset             = 174
    ' Left turn step    = 178
    ' Right sensor program execute = 178
    ' Master command program execute = 176
    ' Wake up           = 177
    ' Sonic sensor program execute = 180
    ' Left sensor program execute  = 179
    ' Orange commands - upper controller
    ' Right hand sweep  = 193
    ' High 5            = 196
    ' Right hand strike = 197
    ' Burp              = 194
    ' Right hand strike 2 = 195
    ' Left hand strike 2  = 203
    ' Whistle           = 202
    ' Left hand strike  = 205
    ' Talk back         = 204
    ' Left hand sweep   = 201
    ' Orange commands - middle & lower controller
    ' Right hand strike 3 = 192
    ' Oops              = 199
    ' Left hand strike 3 = 200
    ' Roar              = 206
    ' Demo 1            = 210
    ' All demo          = 208
    ' Power off         = 209
    ' Dance demo        = 212
    ' Demo 2            = 211
    Here's a pic of the VB app;
    I ended up with an 8-pin PIC controlling my RCA TV, Motorolla cable box, DVD, stereo, RoboSapien 'when I could afford batteries every few minutes', etc. from my PC. Maybe my wife was right...;o}
    -Bruce
    tech at rentron.com
    Default wow
    great info bruce
    i think i want internal pull ups
    is this wpu=1
    thanks for your help
    GPIO.0, 1, 2, 4 and 5 have pull-up enable/disable bits in WPU, but
    OPTION_REG.7 needs to be clear also.
    OPTION_REG.7 (GPPU) is the global pull-up enable/disable bit.
    OPTION_REG.7 = 0 ' GPIO pull-ups enabled by individual WPU bits
    TRISIO = %00000001 ' GPIO.0 = input, rest outputs (except for GPIO.3)
    WPU = %00000001 ' enable pull-up on GPIO.0, disable the rest.
    It's pretty straight forward. Look in your data sheet under OPTION_REG &
    WPU sections for details.
    -Bruce
    tech at rentron.com
    Default pull ups
    have set this up on a board which has a resistor 10 k to ground and a pb to vdd on gpi0.5. this is the way the board is set trying some programs but
    gpi0.5 stays high whenever pic is in socket i guess somehow i am not shutting off the pullups on this port have tried many many lines no changes to this
    any ideas whats up doc
    Post the code you're having problems with. Hard to say without seeing that.
    -Bruce
    tech at rentron.com
    Cool highs and low
    got most things working now except
    cannot get changover from 1 to 0 on gpio.0
    its going high due to the pullup but when i ground does not respond
    might not be explaining this properly but can work on gpio.5
    where i have a resistor to gnd and a pb to 5 volts
    Angry got to be crazy
    What Seems To Be Happening Is I Cannot Get Gpi0.0 To Change State Using The Pullup
    Dont Know If Its A Electrical Issue Or Not See Sample Program Above Just Grounding Pin 7 Momentarily
    But Prgram Does Not Respond Works On Gpi0.5 With A Res Pulled Low And A Pb To High
    Which PIC are you actually using? Your code example above indicates a 12F675, but you asked about the 12F683?
    For the 12F675 you need CMCON = 7 to disable comparators.
    For the 12F683 you need CMCON0 = 7 to disable comparators.
    -Bruce
    tech at rentron.com
    Wink pic
    bruce i tried both but the pic12f675 works with one of my programmers beter dont have to keep swaping out the pic so thats what i am trying now
    really does not mater after i get it working
    How does it work with this?
    @ DEVICE PIC12F675,MCLR_OFF,INTRC_OSC_NOCLKOUT,WDT_OFF,BOD_ON,PWRT_ON
    ANSEL = 0
    CMCON = 7
    OPTION_REG = 0
    TRISIO = %00100011
    WPU = %00000011
    ' Example program from manual to blink an LED connected to gpio.4 about once
    ' a sec
    led var gpio.0
    loop:
       if  led = 1 then
           low 2
           high 2
       HIGH gpio.4
       ' Turn on LED connected to gpio.4
       Pause 1000    ' Delay for .5 seconds
       LOW gpio.4
       ' Turn off LED connected to gpio.4
       Pause 500       ' Delay for .5 seconds
       Goto loop       ' Go back to loop and blink LED forever
    -Bruce
    tech at rentron.com
    Question onward
    this functions but not as expected at first pin to v+ caused change
    than after short time v- caused change which is what i would expect
    dont quiet understand inital operation but this is doing what i want
    thanks
    Thumbs down backwards?
    this program works but still get times when it functions backwards
    should be gnd to pin to work but sometimes after downloading program
    it will be just the oppisite + volts to pin
    any changes that will stop this from accuring
    Are you sure it's not a hardware problem? I ran this on a 12F675, and it works
    exactly as expected. No matter how many times I re-program it.
    -Bruce
    tech at rentron.com
    Cool hardware
    bruce:
    not 100 % sure but seems strange that sometimes + volts cause the pic the way - volts should than sometimes it works just the right way - volts causes the pic to respond properly is there some sort of start up or setting that could cause this maybe pullup not coming on?
    dharwood's Avatar
    dharwood Guest
    Quick question:
    What are you using as V+ for your input signal ? +5v +12v etc.....?
    I had a project where I was trying to read a ~12v input (DCD on a rf modem) and it would sometimes work, other times not. Set up a voltage divider so that my input voltage would not exceed 5v and from that point on, it has worked as planned.
    HTH,
    Dale
    Default an obvious hardware problem
    You have to give us your WHOLE schematic, there's no obvious reason why it shouldn't work.
    If you supply line is pure crap, it will give you crap. In car it's usual. Tie ALL unused pin to somewhere first. ALL floating i/o in car apps (and everywhere anyways, trust me or not i don't care)... is often a killer situation.
    Now if one of your input is MCLR and you didn't use the right voltage divider, your PIC will fall into programming mode... too bad.
  1. Is this a K Type sensor?
    Last Post: - 21st November 2009, 13:55
  2. What's the best way to output 30 to 40 kHz from a 12F683 pin?
    By fizyxman in forum mel PIC BASIC Pro
    Last Post: - 1st June 2009, 00:08
  3. DS1820 with 16f688
    Last Post: - 23rd May 2009, 05:07
  4. Microcontroller with 2 way paging application problem
    Last Post: - 20th April 2007, 17:27
  5. Another RTC, DS1287
    Last Post: - 12th December 2006, 17:07
